blockisle9
About blockisle9
blockisle9's Achievements
  1. blockisle9
    3.5 Hard Start
    My 2017 3.5 V6 NA with 20k miles had a starting issue this morning. I get in car and push start, the car cranks and try’s to start then times out. Push again, same thing, on third try it finally starts. It acted like an older car that was flooded. The car ran perfectly normal after that and started fine every time after that. No check engine light so no code. I’ll mention it to the dealer next oil change, but I’m sure they will say no problem found. Any Ideas? thanks Lenny
  2. Can the dealer reprogram it? For a price, I’m sure
  3. I found it, it stays on for a couple hrs after the ignition is switched off. I was hoping to find something that went off as soon as the ignition is turned off. That’s okay, I’ll use it anyway for now
  4. I do, but I think it’s 110 volt. Also I’m looking for something closer to the tailgate.
  5. Any ideas of what I can tap into for power in the rear of a (2015-2018)? Switched or timed. I want to install a rear facing dash cam with out having to run a wire to the front. Thanks
  6. Update: I installed a fuse tap on fuse 23 (power delay) and this female cigarette plug under the dash. The wire snaked right down the a-pillar to under the dash. The wire tucked nicely under the headliner. I chose this inexpensive Blueskysea B1W camera, its very small and fit nicely under the rear view mirror and is hardly noticeable. The most difficult thing was reaching the fuse panel.
  7. Yea, its a new webcam. Im in and out of the car a lot during the day, so with that delay the web cam will be recording 3 min clips all day. I just figured with all the writing over and over the SD card it would effect it. Plus more ware on the camera. Is it difficult to tap into a fuse?
  8. I had a chance to test it today. It’s 75 minutes. That’s to long. I’ll try and see if I could get to a switched fuse and install a fuse tap. Off hand, would anyone happen to know what fuse is a good choice? Normally I would just test a bunch, but from what I can see the fuse box is a son of a gun to get to..
  9. That will be perfect! I’ll have to test it tomorrow. I thought I had it on for awhile, maybe not long enough. I hope your correct.
  10. Is there a way to change the cigarette power point from on all the time to only on when ignition is on? If not is there anything under or behind the glove box thats switched? lastly, if none of the above how about what fuse under the dash? Thanks for your help
  11. The H9’s are 10 watts higher than the H11’s. Wouldn’t the extra heat damage the projectors? Those projectors are pretty pricey!
  12. I looked for awhile and was also told stay away from LED. I ended up going with a HID set up swapping out my halogens on my 17 Titanium. https://www.lightwerkz.net/index.php/components/hid-ballasts/35w-2a88-hylux-canbus-ballasts.html https://www.lightwerkz.net/index.php/components/hid-bulbs/h-series/nhk-h11.html
  13. I used these https://www.lightwerkz.net/index.php/components/hid-bulbs/h-series/nhk-h11.html I chose the 5500k
