Knuff
About Knuff
Knuff's Achievements
  1. Yes, I went with the simplest way by getting the interface harness with the RCA connector. I was googling everything I could find but I never came across which PID codes to change in order to activate the rear camera function on the nav screen. I have the " As Built" codes and that is no help. I Was hoping someone on the forums might know since i'm not the only one that doesn't want to pay the dealership the money. My local dealership also said they wouldn't touch it anyway. As far as the multiple posts, I was trying to get it activated before my daughter took off to collage. Didn't mean to spin anyone up. Just trying to get it done.
  2. I also have a 2010 Edge limited that has the nav screen. Installed a camera that works (Tested with a separate monitor) but we can't get the system to turn on the function. Dealer said no, can't, won.t, no...... I'm pretty sure that it is possible. Have the video interface that goes directly into the nav unit. Thru forscan, I changed what I thought would be the change (APIM 7D01-01 X*XX-XXX-XXX Changed the astrix to a 2, and an a. Both did nothing. Please help.....
  3. I also have a 2010 Edge limited that has the nav screen. Installed a camera that works (Tested with a separate monitor) but we can't get the system to turn on the function. Dealer said no, can't, won.t, no...... I'm pretty sure that it is possible. Have the video interface that goes directly into the nav unit. Thru forscan, I changed what I thought would be the change (APIM 7D01-01 X*XX-XXX-XXX Changed the astrix to a 2, and an a. Both did nothing. Please help.....
  4. I also have a 2010 Edge limited that has the nav screen. Installed a camera that works (Tested with a separate monitor) but we can't get the system to turn on the function. Dealer said no, can't, won.t, no...... I'm pretty sure that it is possible. Have the video interface that goes directly into the nav unit. Thru forscan, I changed what I thought would be the change (APIM 7D01-01 X*XX-XXX-XXX Changed the astrix to a 2, and an a. Both did nothing. Please help.....
  5. I also have a 2010 Edge limited that has the nav screen. Installed a camera that works (Tested with a separate monitor) but we can't get the system to turn on the function. Dealer said no, can't, won.t, no...... I'm pretty sure that it is possible. Have the video interface that goes directly into the nav unit. Thru forscan, I changed what I thought would be the change (APIM 7D01-01 X*XX-XXX-XXX Changed the astrix to a 2, and an a. Both did nothing. Please help.....
  6. I just bought a 2010 limited edge and wanted to install a backup camera. From what I understand, the sinc screen has a video input. Just tring to find a camera that works well and looks decent. How is yous working?
