Tolman
About Tolman
Tolman's Achievements
  1. Yes new o rings were installed.. we ended up replacing the o rings on the line set tonight.. now we are pulling vacuum and its holding.. this entire thing stems from a problem blowing warm air on the driver side and cold on the passenger side.. coil was leaking ever so slightly so I hope this fixes the problem.. if not I may push it over the edge
  2. Yes new o rings were installed.. we ended up replacing the o rings on the line set tonight.. now we are pulling vacuum and its holding.. this entire thing stems from a problem blowing warm air on the driver side and cold on the passenger side.. coil was leaking ever so slightly so I hope this fixes the problem.. if not I may push it over the edge
  3. Ok problem solved yes I meant evaporator coil deal in the dash.. it turns out the ignition switch and the security ring is the same style and size.. I swapped them around and its fixed.. well kinda.. now its leaking at the o rings popped through the firewall.. new problem ???. Any hints to installing the little metal plate and lubricant for the o rings to prevent leaking?
  4. I have a 2008 Ford Edge that had hvac issues.. turns out the condenser was dirty and leaking.. we removed the entire dashboard to replace the condenser, replaced it, changed a few blend door actuators. Put everything back together and tested the windows, seats, blower motor, and tried to start. Nothing happens but the blinking security light is flashing like I am stealing my own car.. is there a way to reset this without going to the dealer?
