crussellp
Everything posted by crussellp
  1. 2014 Edge SEL AWD How do I know what one (or ones) are bad? I have not found my exact symptom described here: thump thump thump when reversing and the again when taking off in drive after reversing. Goes away at about 15kph then never comes back until putting it in reverse again. Almost 100% certain that it's coming from the rear end.
  2. Thank you I'll investigate further!
  3. 2014 SEL 3.5 AWD Transmission? PTU? If you know and know of a video where someone fixed UT, please let me know. TIA
  4. Good question. The problem first showed up with OEM... blew a fuse, then shortly after a bulb went south, so I swapped out the pair with OEM replacements. I'm about to put in LEDs, not because of the high beam issue but because I find the OEMs dim after driving my wife's Tourag.
  5. Anything other than scratching my head raw is better! Thank you for the suggestion! I'm still guessing it must have something to do with the trailer wire harness, just can't quite figure out how or why! I've redone that connection twice. The last time with solder and shrink wraps. My buddy said it's always the ground. No matter the electrical gremlin, it's a grounding issue! lol! What one??!
  6. 2014 Edge SEL Hi-Beams Fuse (F39 15amp) Blows When Trailering I can use my hi beams to my heart's desire as much as I want without fail... but as soon as I plug in any 4 pin trailer harness and try to use my high beams, BAM! If blows the high beams fuse #f39. It makes no sense to me since there's nothing common that they share. I don't have high beam wires in the back or attached in any way to my trailer. The trailer lights work 100%. I'm so confused and have no idea where to start troubleshooting this problem. So far I've gone through 10 fuses!! - I've redone the trailer harness wires twice. - I've replaced the headlight bulbs. I have no idea where to go next.
  7. Crap! Good thing I didn't pull the trigger yet on some 17inch rims I was looking at!! So 245/60/18s will have to do. I'm one of those freaks that like a comfortable ride over trying to get a behemoth to handle imaginary slalom courses in a mall parking lot! A lot of great info from members quite quickly! Thanks everyone!! Craig
  8. What Size 17 inch Tires - Rough Roads I am a new Edge owner. I just signed and am awaiting delivery of a 2014 SEL with a full load by the end of this week. This SEL has 20 inch wheels with 245-50-20s. I will be driving a great many logging roads as I did with my RAV4 and want to move to 17 inch wheels with much more sidewall to absorb the washboard and bumps better. What are the standard sizes I should look at with this in mind? Does a 16 inch rim fit for even more sidewall? Keep in mind, I want to stay as close as possible to the stock diameter of the the 20s to not offset the speedo too much! TY! Craig
