jayremmington
Everything posted by jayremmington
  1. Thanks for the replies. The leak is coming from the lower weep hole located behind the alternator. I was not aware there was two weep holes. This video shows it exact As far as the question about the PTU Ive had no issues. This thing runs like a dream and other than tires, and breaks this is the first issue its had.
  2. Hi everyone. Ive searched high and low for help on this. Heres the details hopefully someone can help me. 2011 Ford Edge limited AWD 366,000 Kms. (Second owner) Edge over heated the other night. I replaced thermostat thinking that was the issue refilled coolant 450 kms later over heat again, down approx 3 literally of coolant. Checked oil. No coolant in oil. Visually tested and did the crackle test. No leak visible while vehicle is sitting. Started Edge up on a set of ramps and approx 2 mins later there was coolant leaking off the Ac compressor. It appears to be wet above the Ac compressor on the block and coming from the areas behind or near alternator... I cant really see in there to tell where exactly it might be creeping out. Are there any frost plugs? Cooling connections in that area or am I dealing with a cracked head? Any help appreciated
