Everything posted by timfountain
GPSM module location and replacement
timfountain replied to Pepsiluvrs's topic in Audio, Backup, Navigation & SYNC
Ignore. -
Sync 3 & CarPlay problem Arrgh!
timfountain replied to timfountain's topic in Audio, Backup, Navigation & SYNC
Thanks. Off to the dealer when I get an oil change. -
Various gas stations 91 RON. I haven't seen that much dependability on brand in my other cars and the problem manifests across multiple different gas stations. Car has not yet had an oil change, but it is coming up on a year old so will have one soon. I don't see the PTU leaking (as in no fluid under the car in the garage), but after 5k miles I would be very disappointed if it was leaking or had carbon buildup.
I think it is the engine, but not 100%. I always use super. I guess it could be the seasonal mix. I'll keep an eye on it...
Lots of threads on misfires but nothing particularly relevant to my situation. Car is a 2.0 Ecoboost SEL AWD 5,400 miles. When cold and just setting off from my house, going up a steep hill, I get a random hesitation and misfire at partial throttle for the first 1/2 mile or so. It is also getting worse over the last few months. As soon as the engine temp gauge starts to move off the cold mark, the misfire goes away. I've used a good quality code reader and nothing is logged, but it is for sure there, just not enough to trigger the CEL. Any ideas what the problem could be? I am still in warranty but without a hard indication of a fault I suspect I will be told there is nothing for the dealer to attempt to diagnose. Thank in adanvce.
I tried to update sync but get a MEM_ERR03. I've downloaded the file 3 times, verified the zip integrity so at this point I think it is off to the dealer. The car is still in warranty so they need to figure this crap out, I'm done being their beta tester. As Ben Senise says, this setup is not ready for prime time . At all. -
So I had a problem where the car would prompt me every time I started the car to scan for wifi networks, even though system wifi was turned off (side not, does the wifi in a 2018 Edge actually work, I've never managed to successfully connect it to anything or do OTA updates0> Anyways, the recommended fix is to reset the sync unit from the menus, which I did. Now I still get the prompt when starting the car AND Sync no longer detects my iPhone and/or carplay does not do anything no apps, nothing. Literally how can this setup be so darn buggy. It was all working with one annoying issue which should have been solved with a reset, now is does not work at all. In addition my 128GB USB music stick, that, yep, was working 100% for months, now Sync says it media not present. I can see all the files on the USB device when plugged into my PC I've tried another reset on Sync, reset/cold booted my iPhone (latest 12.2 s/w), disconnected the BT link from phone to sync and have been trying various combinations for the last 2 hours. Very, very frustrated and looking for some inspiration. Since it was all working before the reset, I do not think I have a hardware or lightning cable problem.... Thanks in advance for any debugging ideas anyone may have
It's super easy to reposition the coolant reservoir out of the way to get to the back of the headlight, one bolt on the back and a bungee cord to hold it out the way and you're set. If you need to move it a little more, the wiring harness clip pulls out from the reservoir mount to give you even more access. I think it is easier than removing the who headlight, but YMMV.
Hi, not sure what MY you have , but could you please post the wire colors for the permanent and switched +12 wires that go to the mirror? That would be super useful to a number of people (me included) who ask this kind of question fairly regularly. Thank you in advance.
Halogen projectors are useless in the dark. Aimed too low from the factory and bordering on dangerous due to the lack of FWD viz.
GPS not working in navigation
timfountain replied to riche_guy's topic in Audio, Backup, Navigation & SYNC
Good point. I was thinking it was Sync 3. Sync 2 I have no idea, so hats off to you. -
Sync 2 so no idea, -
Ah got it. Poorly worded by Ford IMHO, but that must be it.
Exactly my thoughts. Why put a menu option for something that is non-functional, and why I started scratching my head....
Looking at the brochure for the MY 18, it looks like it was not installed on SEL AWD models. Only SE FWD.... https://www.ford.com/services/assets/Brochure?make=Ford&model=Edge&year=2018&postalCode=25508
No 'A' button anywhere on the dash. Was it an option? TIA - Tim
I have a menu in the vehicle settings for auto start stop, which is checked, but the car never auto starts/stops when at a light etc. I am not too bothered if I don't have the feature (IO it is a PIA) but curious whether it should be working. Comments appreciated. TIA - Tim
Carplay and Waze now supported
timfountain replied to NoDTMF's topic in Audio, Backup, Navigation & SYNC
I noticed my first issue today with Waze. I entered and address, and no matter how many times I clicked on the Go! or start navigation buttons, Waze completely ignored me! Even after re-starting the app and re connecting the phone, it still had the same behavior. Resotred to using Google maps, which worked flawlessly. Looks like Waze still has some 'features' in it.... -
Indeed. Happy camper here finally. I now have two viable alternatives to Apple Maps - Google maps and Waze. Whilst Waze is my normal go-to, I really like the satellite view that you can enable in Google Maps, that is silky smooth and looks amazing. Now if Google Maps added speed limits then I'd be done with Waze.... -
Yay, Finally something that actually works! I find Apple maps to be particularly useless and I was very also unhappy with the buggy Waze support when meant completely disabling Apple Carplay to get something slow and not very useful. I upgraded to IOS 12 and have the latest Sync 3 s/w (IMHO Ford versioning is particularly obtuse but I loaded it as a latest version in the second week of Sept). I now have a new app called Google maps in Apple Carplay and boy does it work well. Fast, simple and accurate mapping, accurate address searching (Apple maps take note) and to cap it all the Satellite view is simply breathtaking on the Sync 3 screen. I hope at some point that Waze is truly integrated, but for now Google maps will work just fine and as I said, the satellite view is amazing. I'll post some pictures in a while.....
- 1 reply
Need 12 volt power only when ignition on
timfountain replied to Xtxman's topic in Accessories & Modifications
There is a switched fuse in the fuse box under the drivers side knee cover. It is extremely hard to get to and Ford used some small-ass fuses that are very fiddly. I ran the wire up the inside of the door seal and under the headlining, as I don't like any visible wires.... I used an Autozone save-a-fuse that gives you a second tap and it worked great from my windshield mounted Dashcam. I used fuse 23 (delayed accessory power) as it is switched but stays on for 5 or so minutes after shutdown, which is perfect for my dashcam as it has a parking record mode. Details of the fuses are here http://www.fordservicecontent.com/Ford_Content/Catalog/owner_information/2018-Ford-Edge-Owners-Manual-version-1_om_EN-US_EN-CA_08_2017.pdf - Tim -
Sync 3 Nav upgrade - quick question
Thank you so much. The suggested value D038 worked just fine. I really appreciate your help. -
Anyone, please if you can help I'd really appreciate it. I am at a full stop here.... Thanks - Tim
