Okie
Everything posted by Okie
I'm assuming you have the 8" My Ford Touch screen. If yours has an older version of Sync 2 there is a way to add navigation to a non-navigation APIM. You will need forscan and the appropriate update file. Do a search there are a bunch of tutorials and videos out there. Additionally you will need the SD Card that has the maps. These can be found on ebay or amazon but ebay is usually cheaper but you do run the risk of getting bootlegs. The A11 (north america and canada maps) are pretty inexpensive on ebay. Additionally you could also go to Sync 3 if you wanted newer features and willing to spend more. I did the Sync 3 conversion on the Edge my son drives and he loves it. See my post on it.
2011 Ford Edge Sync Replacement
Okie replied to magnum3672's topic in Audio, Backup, Navigation & SYNC
You can find Sync 3 options pretty cheap on car-part and even ebay from time to time. I converted my sons to Sync 3 and detailed it here. If you get the correct screen you don't have to worry about 3D printing brackets. -
I'm glad they worked out for you. The ones I printed when I created that thread have been going strong with no issues in my sons daily driver.
Sync 3 Installed in a 2012 Limited
Okie replied to zrt8355's topic in Audio, Backup, Navigation & SYNC
Have you tested it since you turned the vehicle completely off and back on? I had issues like that with my 2013 F150 (3 step heated and cooled) and 2011 edge (2 step heat) when I was programming them. -
Need help with buying Sync 2 replacement module
Okie replied to Bundit's topic in Audio, Backup, Navigation & SYNC
Have you thought about doing a Sync 3 swap? It's more expensive since it involves the screen, hub, GPS antenna and an adapter but the difference is totally worth it IMO. I've done 3 (2 (2 of my personal cars and 1 for a friend). If you did go the Sync 3 route I would check with a local junk yard versus ebay. My friend was able to get a Sync 3 screen and APIM for around $200. In all he spent less than $400 and couldn't be happier. He swapped his due to the black screen issue. My 2 I just hated Sync 2 compared to 3 To answer your questions. 1. I know ford changed part numbers on Sync 2 modules a few times. The modules PNs are different between my 2011 and 2013 but the units are swappable between the two, 2. You used to be able to make a non-nav APIM a Nav APIM but ford patched that somewhat with one of the Sync updates.from what I heard. Depending on the version on the APIM you may or may not be able to do this. 3. The 3rd connector is for another USB port not used in our cars. I can look at mine tonight and edit this post but don't remember if all 3 had the extra usb. Edit: My 2011 APIM is PN BT4T-14F239-CJ Date Code 10-01-10 My 2013 APIM is PN DL3T-14F239-AK Date Code 09-20-12 Both have the extra USB. I'd give one of mine if I wasn't holding onto them to swap back if I get rid of the vehicles. I have no other reason to hold onto them. -
ford sync no longer supported by ford
Okie replied to bubbadewsky's topic in Audio, Backup, Navigation & SYNC
Is it Sync services? I found the following post -
Answeres for all Audio/Video questions
Okie replied to Vfords's topic in Audio, Backup, Navigation & SYNC
I haven't seen this done on a 2011 but it should be possible. Here is what I generally have seen when converting from 4" to 8" (posted in another thread) You might be able to talk to one of the companies that sells a harness to be a test subject for a discount etc. https://www.fordedgeforum.com/topic/24145-changing-the-2018-ford-edge-se-head-unit/?p=183989 -
Dead Sync SYNC - Black Screen of Death ...
Okie replied to Kwmck's topic in Audio, Backup, Navigation & SYNC
My understanding most of the issue is related to the APIM. Sync2 APIMs can be bought on ebay pretty cheap but you never know how long they will last. You may be able to find a user who updated to Sync3 and may be able to get you the complete Sync2 unit cheap. If I wasn't holding onto both of mine to put back into my 2011 Edge and 2013 F150 I'd send you one for shipping cost since they are really just collecting dust until I get ready to trade the vehicles off. -
Sync 3 APIM + Screen $375 right here
Okie replied to so_edgy_bro's topic in Audio, Backup, Navigation & SYNC
I think your 2015 model has different brackets than my 2011 when looking at pics. I'd send you a spare set I made for free but I don't think it would work for your model year. -
Waze via AppLink - is it working?
Okie replied to candurin's topic in Audio, Backup, Navigation & SYNC
You have to turn off Android auto and carplay in settings to use the mobile apps -
Sync 3 Android Auto Compatible Phones
Okie replied to FishinFreaks's topic in Audio, Backup, Navigation & SYNC
As others have said try a different cable. I've used several phones with AA across multiple Ford's and aftermarket headunits. Everytime I've had issues it's been the cable. Length and quality can all cause issues with AA. On my sync 3 specifically I've had issues with Anker cables over 1.5 feet. I'd get errors that there was a problem with AA and it would disconnect. -
4D has some good stuff but it is expensive compared to what you find used. Their hubs and GPS module are over twice the cost from ford and amazon. If they are all new parts for the screen and APIM then the cost is probably fair. If they are selling you salvaged parts I'd look elsewhere for the screen and APIM. I bought one of their adapters for the hub power and it worked well. I made an adapter on my F150 but didn't want to sacrifice the part from the sync 2 hub this time around on the Edge. This is just my opinion. I could easily justify the Sync 3 upgrade for $500 - $700 based on the cost of a decent aftermarket headset with the same features. Once you start talking $1500 - $2000 though it was harder for me to swallow. -
says its without the APIM on the listing...states screen only. Hopefully you talked to the seller first. -
So_Edgy - Candurin is right that the SB screen is the non-recessed on the sides. I put an overview of the details I found out while searching for APIMs and Screens in the following post Sync 3 Overview Looking online it looks like the brackets are completely different than my 2011 Edge for your 2015. It looks like they bolt to the top and bottom of the screen versus the sides. This is just from looking online so I can't speak for sure. You may be able to make a bracket to tie into the top and bottom brackets that mounts to the side of the screen you got. You may also be able to talk to the person you bought it from and see if they have a different model since they are a recycler -
Sync 2 to Sync 3 in 2011 with 3D printed brackets
Okie replied to Okie's topic in Audio, Backup, Navigation & SYNC
I thought I would post my APIM settings. Details of my vehicle. 2011 Limited AWD with heated seats, Sony, HD, dual zone, ambient lighting and a Nav APIM. See attached image -
I was getting that when I had the antenna closer to the front of the dash. Since I moved mine as far back as I could on the cross member I haven't had this issue. I originally thought it might be the antenna itself so swapped the one I used on my F150 which has worked without issue for a year and it had the same issue. Also sometimes when it would work it was inaccurate. Relocating it as I stated above I've had no issues for the past 4 days. -
SWRStock. Good job on the screen There's a free app on the F150 forum called As Built Hacker 2.2. It lets you pull up details about your modules and deciphers the available options based on your VIN. It's a good starting point. I think it would have made things a little easier when I was looking for Forscan values. I can also post my Forscan settings too for my 2011 limited if that helps people here. -
Official Release of V3.0 for SYNC3 Has Begun
Okie replied to jmr061's topic in Audio, Backup, Navigation & SYNC
From what I remember if you check for updates once and then turn wifi off it will no longer prompt you. I don't get the prompts on either vehicle I updated to 3.0. I also have never had it install an update over Wifi. It checks but never downloads them. My assumption is when it checks your VIN it doesn't see it as a valid Sync 3 vehicle. -
Backup Camera upgrade with active Gridlines
Okie replied to gwbmcse's topic in Audio, Backup, Navigation & SYNC
I have a cheap $10 adapter I use and another that has the switch. Both I got on Amazon. I 99% of the time use the $10 adapter. Though to be honest I've only done a few things outside of APIM setup (Disable tpms, set turn signal behavior, enabled high beam with fogs, read door lock code). There's definitely pros going to a wired adapter especially if they work out the bugs with the firmware programming but if you aren't planning on doing forscan mods all the time you may not need it. -
I'm sure it gets the active line info from your steering wheel location. I haven't been able to get this to function on the 2011 edge or my 2013 f150 both with sync 3. On my 2013 it shows the lines on the sample image under vehicle but not on the actual camera. The 2013 raptor has these lines on the front and back so I was more hopeful with it but still wasn't able to get it to work. Since it wasn't there on the MFT with the edge I didn't spend much time on it. -
Changing the 2018 Ford Edge SE Head Unit
Okie replied to LJA414's topic in Audio, Backup, Navigation & SYNC
If this is the 4" Sync screen version you can do the switch but you will need a minimum of the following Dash panel with AC controls ($100 - $200) Harness to adapt the 4" Sync harness to the 8" harness (there are different versions of this depending if your original AC controls are manual or auto) ($250 - $350) Adapter for the backup camera input to new harness (with above most likely or a $25 - $50 addon) Sync 3 APIM and Screen ($300 - $700 depending on Nav or non nav - keep in mind this is used parts too not new) USB cable from the APIM to your console ($35 - $75) you may be able to use a male to male mini usb cable but it wouldn't be locked into place (also I haven't tested this myself.) USB Hub for Sync 3 ($50) GPS antenna ($10 - $20) You will also need to program the APIM for your vehicle as well. The software (Forscan) is free but you will need a OBD2 bluetooth or usb adapter ($10 - $50). I've seen some people build the harness themselves on the F150 forums. There are companies that sell PnP kits as well. Prices I quoted are just for things I saw from different vendors when researching my recent options when buying my son a car. Because of all this I decided to get one that already had a Sync 2 touchscreen which doesn't require a harness kit. -
So Edgy, You will also need a GPS antenna for Nav or compass and a pigtail or an adapter to supply power to your USB hub. Overview and differences in APIMs: I've done two Sync 2 to Sync 3 conversions (My 2013 F150 last year and my sons 2011 Edge last week). APIMs at least 2016 models that have the 2nd to last letter with a C or K are navigation models, 2017 2nd to last with a C is navigation. All others I've seen which with a B,D, or F 2nd to last letters are non-navigation but this may vary. Best to pick one that shows the unit powered up at some point or gives you the VIN of the vehicle it came from so you can check its As built data to see if it had Nav or find the window sticker for it online to see if it did. Screen and APIM assemblies that end with SB are the flat sided and those with SC are stepped or indented. I'm unsure of which model the 2015 uses but you can tell by looking at your Sync 2 screen with the bezel removed. The 2011 had the stepped screen. I used a SB assembly so had to 3D print some brackets to fit. My post is on the forum Configuration: Once you install the screen you will most likely need to program it to work with your vehicle. There is a free Windows program called Forscan. You can use it with a wired or bluetooth OBD2 dongle to program the options you have. People generally look up the "As Built" information of a vehicle that originally came with Sync 3 that has the same or as close as possible options as your vehicle. From there you can look at the Sync 3 spreadsheet on the F150 forums to tweak as needed. Since yours is a 2015 a similarly specified 2016 vehicle will probably work. Updating: Updates have to be for the correct type of APIM you have so Nav or non-nav. The difference between the two are the amount of storage space on the APIM. If you try to install a NAV update on a Non-Nav APIM it will hang once it fills up the storage space (since it doesn't delete old data until the end) and no longer boot to the user interface. There are ways to recover from this with a modified install file but the best bet is to make sure you are updating with the right file. I used a VIN from a wrecked explorer that had nav to get my updates from ford. I updated form 2.2 to 2.3 to 3.0 on the F150 and 2.3 to 3.0 on the Edge using the same USB stick. This might not always work however as there have been recent hardware changes to the 2018 version of the APIMs. As long as it matches for the APIM year and type you have you should be okay. Random stuff: There is a current modder group working on additional changes to the Sync system. I know they've gotten Nav to work on Non-Nav units and customized the splash screen and background. I typically stay away from this since you are always dependent on said modders for updates. Honestly even though my APIMs are both Nav I never use the factory nav. I use Android Auto all the time. Once Waze does the update to use it directly on the GUI (hopefully this month or next) I see no reason why anyone would use the factory navigation maps unless they were in an area without an internet connection. There's also Sygic support too but I've never used it so can't speak on it. Cost: You can sometimes find non-nav screens and APIMs for around the $300-$400. Nav screens generally go around $500+. You can find ones for less sometimes if you are lucky. I bought both of mine with APIM and screen together. If i would have bought them separately it would have cost me around $200 more. Sync 3 vs Sync 2 No comparison here. I originally did my 2013 due to the lag of clicking an option to when that option was performed. It drove me insane. The screen is better and the layout and app support is better. Android Auto and Carplay is just the icing on the cake. Good luck Hopefully this helps. -Deric note: edited to clarify APIM nav/non-navs I've seen. -
FYI I added the brackets to thingiverse https://www.thingiverse.com/thing:2848653 -
I updated to 3.0 in my 2011 Edge and 2013 F150 the other day. One bug I found is with Android Auto connected you used to be able to click maps at the bottom or on the left of the Sync home screen (where the default maps are when not in AA mode) and it would take you directly to maps of Android Auto. With 3.0 it does nothing. Just toggles with no function. I use this all the time when if navigating and needing to toggle my seats on or off. Hopefully they fix it if 3.2 gets an update release for existing APIMs
