so_edgy_bro
Everything posted by so_edgy_bro
Hi all, I sold a fully-functional MFT apim+screen combo after I successfully installed the Sync 3 equipment, and the guy who bought it is saying the GPS is not catching any signal at all. Similar to the Sync 3 apims, is there some kind of antenna that needs to be bought and installed? Just want to make sure I help my buyer out as much as possible. Thanks all!
iphone plugged in dock for the car
so_edgy_bro replied to Fastfwd75's topic in Audio, Backup, Navigation & SYNC
https://www.proclipusa.com/device/phone-holders/apple-iphone-x Im probably gonna cop one of these - seems like the best thing out there for a simple mount+data sync solution. -
Waze via AppLink - is it working?
so_edgy_bro replied to candurin's topic in Audio, Backup, Navigation & SYNC
Hey Candurin. I have not had any other devices connected at all while operating Waze - I do need to test that. -
UPDATE: WAZE WORKING ON SYNC 3 (MFT to Sync 3 Hardware Conversion) --- See below description: Candurin- Yes, 3.0.18093 installed properly. Thanks for your help, man! You're a great contributor on this forum. Below is my most recent feedback email to Waze's Beta support team, describing my working Waze+Sync 3 combo: "This morning, Waze worked for me on my commute without a problem. As it is currently a known issue, the app is a little laggy, processing at low frames per second on my Sync 3 system. Outside of the slight lag issue, the app worked perfectly on my Sync 3 AppLink system in my 2015 Ford Edge Titanium. The vehicle was not originally equipped with Sync 3 capable hardware, but I installed it myself. The current known settings and specifications for my working system are below: Sync 3 version: Build 3.0.18093 (Vehicle has appropriate BuiltAs settings, which could have contributed to Waze working) iOS version: 11.3.1 Waze version: 4.39 (beta) Sync 3 settings: - CarPlay: Disabled (not deleted) - Mobile Apps: Enabled - Mobile Apps via USB: Enabled - Notifications permissions within Sync 3 Mobile Apps Settings: All enabled - Waze set as default navigation: Enabled iPhone Settings: - Location settings: all enabled within iPhone settings (Waze set to ‘always’, will test later on ‘while using’) - Waze access permissions: all enabled (notification preview settings allowed with/without phone unlocked) - Background data: all enabled - CarPlay settings: vehicle profile deleted - please test with and without your vehicle profile - Bluetooth: enabled and connected to the vehicle for voice and media Waze settings: - All default as when first installed - All permissions to access phone’s content enabled (contacts, location, calendar, microphone, etc.) Other things to note: - Sygic nav installed and confirmed working (Waze worked for the first time immediately after I installed and tested Sygic) - Alexa installed and confirmed working, with Waze set to default maps within Alexa (may be another reason Waze began working properly) Picture is blurry because I had to take it from my MacBook" EDIT: Also, phone does not seem to get too hot, but I enabled low battery mode anyway. Phone remained nice and cool. However, with many reporting the phone to get extremely warm, I'd advise getting an AC Vent mount for the phone to keep it in front of the cool air flow and mitigate potential heat-damage. -
I modified the as-built using Forscan, with everything updating correctly to match each specification of my vehicle. Still no joy with Waze - any ideas? CarPlay works, even though I don't use it lol -
Candurin, just tried that and no luck. Should I seek a different sync 3 build? The APIM was pre-programmed with everything my car has available, so I didnt program the as-built data to it (yet)would that make a difference? Alexa and Accuwether work fine in applink, just waze is hanging on waiting for device -
MFT to Sync 3 conversion complete, update to Sync 3 (build 18025), CarPlay and everything working. However, Waze hanging on "Waiting for Device" and will not advance past this point. Any ideas? -
Sync 3 Installed in a 2012 Limited
so_edgy_bro replied to zrt8355's topic in Audio, Backup, Navigation & SYNC
Having issues with getting power to the new sync 3 usb hub. Can I just tap the power into the cigarette lighter? Or does anyone know exactly which wires from the existing connector I need to tap into? -
Hi candurin, thanks for the help. I asked the seller to send me the product number, and they said the unit they sent should be 18b955-sc I may get extraordinarily lucky, all things considered. If it is the right screen, I will have the whole job done, all materials included, for under 500 bucks. Fingers crossed!! -
If I I have to get mounts for the touchscreen I purchased, where do I get the mounting brackets for a 2015 Edge doing the sync 3 conversion? Ive looked everywhere and Im coming up empty handed. -
Sync 3 APIM + Screen $375 right here
so_edgy_bro replied to so_edgy_bro's topic in Audio, Backup, Navigation & SYNC
Look at the touchscreen shown in this ebay listing, can anyone tell me if Ill need to find mounting brackets for the APIM, and wher is I can get them? -
Candurin, thanks for the heads up. I had the seller send a video of the screen and APIM being operated to confirm the version. Navigation confirmed US- making out of this like a bandit for the whole deal. -
No worries, Okie. I appreciate your help and insight thus far- its nice of you to help out a new owner while I get the hang of all this! Any direction I should go in order to get the brackets I need? -
Update: the seller ended up offering to sell me touchscreen+apim for $310 so I'd remove my nasty review/feedback. Very excited for that to come in. Okie, you're the one who 3D printed the brackets right? How much would you charge for me to get some from you? -
I was notified that they made a mistake in the listing and asked them to honor my purchase. They since changed the listing to not include the APIM module. The seller than proceeded to tell me I thought you Americans were righteous and upright before doing foreign trade So that went well. FORD LINCOLN MYFORD TOUCH SYNC 3 TOUCH SCREEN 8%22 navigation screen | eBay.pdf -
Answeres for all Audio/Video questions
so_edgy_bro replied to Vfords's topic in Audio, Backup, Navigation & SYNC
VERY helpful write-up, I appreciate you taking the time to help me out. I think I found a deal on one with Nav and a screen for 374, which I started a thread for with the link to the seller's listing on eBay. he had 10, and I got the first one! -
Its ebay guaranteed (get what you ordered, or money back guaranteed) so I went ahead and got one. People are watching though, so move quick! https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F232731306548
I realized that, thank you for confirming. I cancelled the order and ordered this one https://www.ebay.com/itm/FOR-FORD-F150-PICKUP-2107880-16-17-RADIO-INFO-DISPLAY-SCREEN/352327024969?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Will this apim+screen work? -
Hi all, I found an APIM module and touchscreen from a 2016 explorer (APIM# db5t-14f239-ar, Touchscreen# db5t-18b955-FC) and wanted to see if y'all could confirm that these units will work for my 2015 Edge Titanium conversion. I also wanted to see if anyone knows if this APIM has the nav built-in. Thanks y'all https://www.ebay.com/itm/332546105022(link to the unit I bought) -
H2GT-14G370-FCD -- 2017 Edge HB5T-14G370-FCD -- 2017 Explorer HA1T-14G370-FBD -- 2017 MKX these are some APIM's I found on the internet. From what I can see, it looks like they are Sync 3 with Nav. Does anyone know of a way to get a hard yes or no on confirming an APIM module by the number? Thanks!
Found one numbered #DS7-T14F239-CJ from a Ford Mondeo, manufacture date 9-25-15 Looks like its in Europe. Will it work or do I have to find an APIM from a US model vehicle? What all apims and screens are compatible? Trying to upgrade MFT on a 2015 Edge Titanium on a budget Thanks
Hi all, (Pardon me if this is not in proper forum etiquette, Ive dug around the forum and internet and havent been able to find concrete answers on this) Im new to the forum and relatively new to my vehicle, and Im hoping to get some precise info on a project I want to start. I have a 2015 Edge Titanium with integrated Nav, and I want to replace the MyFord Touch with the necessary hardware to: - Add Sync 3 compatibility - retain all current integration with MyFord Touch (I.e.: steering wheel controls, instrument cluster integration, etc) My current research concludes that I will need to source the following: - a touchscreen/info display from a 2016+ Edge - a Sync 3 APIM module with Nav (vehicle specific?) - Sync 3/CarPlay compatible USB hub Are there any other specific parts I will need in order to retain all functionality, while adding Sync 3? Thanks, and looking forward to learning more from the community here.
- 1 reply
- sync 3 upgrade
- mft to sync 3
- (and 6 more)
