todd92
    3
About todd92
7,580 profile views
  1. I own 2, one in 2015 F150 (the very first 2.7's) and one in a 2020 Edge ST and neither uses a drop between changes. The 2.7 is widely regarded as one of the most reliable and durable engines Ford makes.
  2. The 2.7 is NOT known to have oil consumption issues.
  3. You got the Performance Brake and Tire Package. Summer tires, which wear out twice as fast and high performance Brembo brakes which also wear more quickly. I made sure my ST had neither when I bought it, so it came with all-season 20" wheels and tires and standard brakes. Both are wearing fine. Why are you angry and blaming Ford or the dealer? You bought a car with a performance option you didn't need, understand or want. It's no ones fault but your own.
  4. Hence API SN+ then SP and ILSAC GF-6A specs for oil, which greatly reduce the likelihood of LSPI.
  5. I own 5 Ford's all have ASS, it works fine in all of them, it doesn't bother me, it's easy to control with brake pedal pressure. I've only put in one new battery, in the 2015 F-150 last year, not because it died, but I figured 7 years was good enough. I kind of get the teeth gnashing over ASS when it first appeared, but it's been around for a long time now. I can't believe people are still bitching about it and blaming it for everything and anything that goes wrong with thier car.
  6. todd92
    Short Rant
    The Edge is a truck? I think not.
  7. Summer tires aren't meant for the Winter, regardless of brand.
  8. They don't have the same engine. Ford specifies 5W-30 for turbo motors and 5W-20 for normally aspirated motors. You won't hurt anything putting 5W-30 in your Ecosport. Look in the Owner's Manual, only the US specifies 5W-20, for CAFE reasons, outside the US it's 5W-30. I put 5W-30 in all of my Fords.
  9. BG products are pure dealer service department upsell snakeoil. Don't waste your money.
  10. todd92
    ST Overheating
    Thermostat stuck shut and radiator 'not flowing' on a 2 year old car with 3,000 miles? Something very wrong.
  11. Also, I have no idea what a 'certified' mechanic is. Credentials don't mean anything. There are plenty of incompetent doctors, lawyers, realtors, accountants, all of whom have certifications.
  12. There is something very wrong with that engine, I've never changed a spark plug in anything other than a 2 stroke that had that much oil and carbon on it. I'm not saying that plugs might not need to be changed more often, certainly on tuned engines running higher boost. But that video is not at all representative of what a spark plug would look like even after 100,000 miles.
