Inno
About Inno
1,326 profile views
Inno's Achievements
  1. I need to know if someone knows where to get the best connection to connect a Subwoofer on my edge ST 2021, I been looking all over on the internet but nothing yet, I don't know if the past models of ST have the same connection.
    please help...
    1. Show previous comments  1 more
    2. MYECOBEAST68
      MYECOBEAST68
      thanks for your comments, I just like to be different, every car the I owned is been customize; is my hobby.
      ok back to your question about the mud flaps, well if I remember correctly I did cut small portion on the top to make flush with the shape of the fender, also you need to punch a new holes for, so you need to be patient for this and once you think is the right distance make the new holes.
      I hope this will help you.
      I will check closely and take a picture and I send to you, sounds good to you, let me know.?
    3. CVCashmere
      CVCashmere
      Thanks!
      Also...did you use the 2019-2020 mud flaps off of a regular Edge?
      thanks
      CVCashmere
    4. MYECOBEAST68
      MYECOBEAST68
      I just ordered online, the description on the web site said it fit my edge ST 2021, I give a try, did minor adjustments and it work for me.
  2. Boil out! Thanks for the? words!
  3. Do you have the part number?
  4. You Are right. I have choosen 3.5L section to post. This is why i didn't give this info. The two times it happen, the vehicle was not moving. I just stopped(with engine on) to make a call. The third time, the vehicle was moving but slowly (arround 20mph)I was preparing to turn. There's no any leakage. The coolant will only go out after the alarm is popped out. Pls use you diagnostics crystal ball now and help. ??
  5. It is 3.5L and there's no leak. The coolant is drained out after the warning alarm, not before. When the engine is hot it push the coolant out.
  6. There's nous leackage. And I Havel changed the water pump 3 months ago.
  7. Engine overheat and all the coolant was drained out. I refilled it and it happen again the next day.
  8. I have replaced the evaporator core with a new one because of the trouble code B1B71 - Evaporator Temperature Sensor but the issue and the trouble code still exist. I actually have 2 trouble codes as below: B1B71 - Evaporator Temperature Sensor B1086 - Air Distribution Damper Motor Note: it is a 2011 Ford Edge Limited
  9. After changing the evaporator core the A/C is not working properly. 1. The air is blowing only from the front vent. 2. The air is not cooling all the time. Sometime it blow cooled air and most of the time it is hot air which is blowing. Does anyone have an idea of what it could be and how to deal with it?
  10. The battery is new. The issue happen just after tried to enable navigation and radio odd frequency.
  11. If the fan speed is not at max, the engine can start but in max position it cannot. For example if the fan speed is at the middle or below the middle the vehicle can start. Once the vehicle starts I can adjust fan speed as I want.
  12. Another question is coming up: Why the engine cannot start with AC on?
