AntDeek
Everything posted by AntDeek
AntDeek replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I have a theory that our motors eat water pump bearings due to lower film strength over a long OCI especially at 10k on conventional like Ford says is okay. It’s cheap and fast enough to change so I don’t really care. -
Heads up guys. New Forscan update has lots of fun BodyCM parameters to play with. Back up your ABD! 6qts of Rotella Gas truck full synthetic and am FL-500S. Started doing changes based on engine hours rather than miles ~3000 miles is when I change. I need this car to last me lol -
Nope, its the remote start hood pin switch, I used this and forscan to get RS.
Used a shampooing machine on all interior cloth surfaces. Very happy with the results! I recommend renting a rug doctor every now and then it really makes a difference. Also did an oil change, 6 qts of Rotella Gas Truck full syn 5W20 and an FL-500s. Drain and filled the trans with some new Mercon LV. -
Aaaaaaaaaand first code has arrived. Drivers side impact sensor. Fuck me. The rest of the car is dry now everything else seems fine and all IDS tests clear. I’m going to replace the crash sensors that were submerged. Gonna save this car
This was a flash flood, all water was gone within an hour. Crazy how fast it happens. I wish I could get the township to pay
I recently had another car (2017 explorer) totaled and replaced on my insurance. The roof is leaking on my house, and we cannot afford the rate increase right now if I contact the insurance. I’m going to dry it out thoroughly. All door panels and interior trim has been removed. The water was only in the car for a few minutes and it drained very quickly. We shall see, thank you all for the kind words
Thank you. It was just rain runoff water, no dirt. She’s drying currently. I don’t think I will contact the insurance
Yeah. I had two oxygen sensor codes from Forscan when I was forced to drive through water, but once the exhaust dried all systems came back. Every single Module IDS test run on Forscan passes clean
Last night the sewer backed up (flash flood water, clean thankfully) and my street flooded when I was awoken by thunder. I had to drive my edge out of standing water, up to the shifter. Oil is clean but will still be changed tomorrow trans fluid is clean but I’ll do a drain and fill tomorrow. no codes.... yet any tips friends? im absolutely distraught. Luckily the amplifiers were on the load floor and didn’t get wet
What is the factory bumper light behavior on 11-14?
AntDeek replied to AntDeek's topic in Accessories & Modifications
Thanks buddy -
Is the basic sound system amplified?
Thanks guys. Wired in a 50w x2 to the front speakers. Incredible difference -
Does anyone know if the basic non sync sound systems are amplified or not? Thank you.
No lie, just did that yesterday. Evap code is gone!!
Hey guys, So I accidentally broke the retainer clip that held on the EVAP purge line going into the purge valve directly next to the throttle body. 3/8 and 6/16 fuel line clips do not work. Now I have P0456, it got brittle and snapped when I removed it. Does anyone have a part num??? 3.5 2013 SE Thanks friends
https://imgur.com/a/EYW3sBL ^^^^^^ Photos Link**** It took me around 5 hours, I took my time. Motorcraft SP-520 plugs and a MAHLE intake gasket. Also did the PCV valve, Motorcraft. My 2013 had a hose and hoseclamp on the PCV valve. It seems every other 3.5 has a heat shrink hard elbow. What does your's have? What does this indicate? How do I tell if my valve cover is the "updated" design? Thank you guys, enjoy the photos. Fuel injector cleaner must work pretty well, look at those clean valves!
How quick are the 3.5 NA 2WD edges? I remember seeing somewhere that a 3.5 NA base beat a 3.7 Sport AWD. Less rotational losses in power from the AWD system, and its lighter!
I am happy with the beam pattern. I love how much better I can see at night time. Aimed enough from factory that it doesn’t blind oncoming drivers. -
Ordered cheap 9012 LED headlights from Amazon. They look f*cking awesome in my projectors. -
RCA (Low Level) Output from factory head unit?
Sounds great Lots of thump. I tapped in to the rear speakers in the door behind it's factory connectors, using Posi-Taps. -
AntDeek posted a topic in Accessories & Modifications
Hey friends, Has anyone figured out a way (if any) to get low level outputs from a stock non sync base audio system? For my sub now, I am running with the rear speakers to a line output converter. Thanks!
