lazyace
About lazyace
648 profile views
lazyace's Achievements
  1. Had this been about a year ago I would have totally agreed with you because I too had the door ajar problem but I found and used the work around I read on this site utilizing a reed switch on the appropriate wire in the door and it worked like a charm. Sorry but I can't remember the original poster's name on that particular fix but it solved the problem and I am very grateful for the workaround.
  2. Thank you for responding WWWPerfA_ZNOW. I guess I should have mentioned that I replaced the key fob battery thinking at first this would solve the problem. Also, I had a new vehicle battery installed this past May. The problem with the locks began before the new battery install so that shouldn't be a factor. Any idea where the Remote Keyless Entry module is located? Perhaps if I were to drop power to it and "reboot" it that might do it. Worth a try but I have not a clue as to where it is located. I read somewhere that it was a Siemens box but I'll be darned if I can find the article that I read this in.
  3. I have a 2012 Edge Sport. I have had this vehicle for a little over 2 years now. My door locks have now developed a mind of their own. Sometimes they will unlock with the fob or the door keypad and sometimes they won't. At times, even the inside door lock switch on the driver's door won't work. If I turn the key from off to the on position and back off again, open the driver's door all works again. I have rebooted the my touch Ford sync computer numerous times but haven;t had any success solving the "possessed door lock" system. Ist there another computer I can reboot that controls the locking system? If so, how would I go about rebooting that system?
  4. I have successfully downloaded and installed V3.10 but now have a question. Will this update work with an iPhone 7+ or 8+? I have a 2012 Edge Sport and need a new phone but would like to get a phone that would be compatible with Sync2. The LG I now have works well, text, phone, caller ID and such but the phone is on death's door and needs to be replaced.
