Rizsin23
Everything posted by Rizsin23
yes, it's still available. It would be coming from New Hampshire
Bump
No, I will give you the email of a guy who does it. Or if you are good with forscan, you can do it yourself. What are the options of your vehicle? It may not have to be programmed.
Bump
I have a complete Sync 3 Navigation system for sale. Includes everything needed to upgrade the Sync 2. Screen, APIM, GPS antenna, and blue USB hub. It is on the newest version of Sync (3.4) everything works perfectly. The only thing needed are the radio brackets from your old screen, and it's going to have to be programmed to your Edge. I sold my Edge, so it's no longer needed. Contact me for information or more pictures. $550 firm plus shipping.
Sync 3 screen and apim for sale
Rizsin23 replied to Rizsin23's topic in Audio, Backup, Navigation & SYNC
Thank you, I will do that!- 3 replies
- sync 3
- navigation
It's going to need to be programmed for your specific Edge. Mine was a 14 SEL with heated seats.- 3 replies
- sync 3
- navigation
I have a complete sync 3 system (nav) for sale. Includes everything needed to upgrade the sync mft. GPS antenna, and blue USB hub needed to complete the upgrade. It is on the newest version of Sync, everything works perfectly. The only thing needed are the radio brackets. I sold my Edge, so it's no longer needed. Contact me for information or more pictures.
- 3 replies
- sync 3
- navigation
Just a follow up on this. I disconnected both the positive and negative sensors on the battery, have not had a problem since ?
GPSM module location and replacement
Rizsin23 replied to Pepsiluvrs's topic in Audio, Backup, Navigation & SYNC
thanks for the info. I should have updated the post. You are correct, right behind cluster to the right. Very easy to get to. I unplugged mine, as I am running sync 3 and it doesn't use that gps module. -
Do you remember where exactly it was located? How could you tell? -
Thanks for the responses guys. I have tried everything to rule out a parasitic draw, cannot find anything. The battery was replaced 38 days ago with a new Motorcraft 65 series.I reset it via forscan when I installed it. I wanted the extra CCA as I live in New Hampshire and it gets very cold here. Not sure how I can find out if it's the +ve lead...The vehicle sits for 9+ hours uninterrupted every night in my garage...
Hi all, I was curious if the 2014 Edge SEL has a connector for the BMS? Where is it located, and can it be disconnected without causing harm to the vehicle, battery, etc...my problem is that even after I charge the battery and the charger shows 100%, the forscan app does not. It's about 85-89%. I don't know if this BMS has anything to do with it, and if it can be changed. Any information would be welcomed. Thank you!
Thank you. I am going to get a grounding block and ground all accessories to that as I've been having battery problems.
Just curious if anyone can tell me where a good place to ground HIDs/accessories. There is an extension off the negative cable, is that the best place or is there somewhere better? Thank you! 2014 edge sel btw
You're absolutely correct Candurin, it is the key that drives the cost. I apologize for the post, but cannot seem to find how to delete it...
this is what I am selling, minus the key https://www.ebay.com/itm/11-thru-14-Edge-OEM-Genuine-Ford-Remote-Starter-Kit-Single-Key-FACTORY-NEW/161653104823?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l9372
yes it plugs into the TPMS located behind the drivers side. Takes 5 minutes to install, 10 if you have the power liftgate
Came out of a 2013 Edge SEL, was put in January of this year, so only used a handful of times. Traded in the Edge, took out the antenna. Asking 50 for both. Does not include the key. Want pics, let me know. You will have to provide the cut/ programmed key, and enable in vehicle using forscan.
DA8Z-19G364-A Remote Start
Rizsin23 replied to rcahoy's topic in Alarms, Keyless Entry, Locks & Remote Start
I have an antenna and hood switch for sale that came out of a 2013 SEL, where would I post it mods? -
Rizsin23 replied to ben senise's topic in Accessories & Modifications
Thank you, I will have a look see. I have so many open tabs right now lol -
Hey all! Looking to enable remote start in BCM and IPC for a 13 SEL with heated seats and also a 14 SEL with heated seats. I have a couple of different settings, used with the explorer and a couple using the fusion. I'm not exactly sure which to use as they have different values. Looking at the fusion sheet, they use 726-60-01 and also 720-02-02. Explorer has 726-19-01 and 720-01-03. Could someone please clarify which settings to use? Thank you much!!
