Rizsin23
About Rizsin23
7,873 profile views
Rizsin23's Achievements
  1. yes, it's still available. It would be coming from New Hampshire
  2. No, I will give you the email of a guy who does it. Or if you are good with forscan, you can do it yourself. What are the options of your vehicle? It may not have to be programmed.
  3. I have a complete Sync 3 Navigation system for sale. Includes everything needed to upgrade the Sync 2. Screen, APIM, GPS antenna, and blue USB hub. It is on the newest version of Sync (3.4) everything works perfectly. The only thing needed are the radio brackets from your old screen, and it's going to have to be programmed to your Edge. I sold my Edge, so it's no longer needed. Contact me for information or more pictures. $550 firm plus shipping.
  4. It's going to need to be programmed for your specific Edge. Mine was a 14 SEL with heated seats.
  5. I have a complete sync 3 system (nav) for sale. Includes everything needed to upgrade the sync mft. GPS antenna, and blue USB hub needed to complete the upgrade. It is on the newest version of Sync, everything works perfectly. The only thing needed are the radio brackets. I sold my Edge, so it's no longer needed. Contact me for information or more pictures.
  6. Just a follow up on this. I disconnected both the positive and negative sensors on the battery, have not had a problem since ?
  7. thanks for the info. I should have updated the post. You are correct, right behind cluster to the right. Very easy to get to. I unplugged mine, as I am running sync 3 and it doesn't use that gps module.
  8. Do you remember where exactly it was located? How could you tell?
  9. I doubt this thread is still alive, but does anybody have the .PDF for installation?
  10. Thanks for the responses guys. I have tried everything to rule out a parasitic draw, cannot find anything. The battery was replaced 38 days ago with a new Motorcraft 65 series.I reset it via forscan when I installed it. I wanted the extra CCA as I live in New Hampshire and it gets very cold here. Not sure how I can find out if it's the +ve lead...The vehicle sits for 9+ hours uninterrupted every night in my garage...
