Everything posted by Gregertech
Help finding side window deflectors
Gregertech replied to Gregertech's topic in Accessories & Modifications
I picked up a set of AVS low profile since the look like they were the closest I could find online. I don't have them on the car yet but they look very similar, if not the same. I'll post pics after I install them, but I'm waiting for the weather to warm up since they are stick on. -
I think it should be noted that 2015 and up Edge do in fact have the ability for rear camber adjustment. I just learned this information from somebody on Facebook. It is not obvious that camber is adjustable when looking under the vehicle and doesn't seem to be widely known. I just got my Edge re-aligned, I had to show the tech where the camber adjustment was, and all numbers are within spec now, before this the rear camber was -3.0 and -2.0. The photo shows the location of the bolt, subframe side, and the elongated hole which allows the upper suspension arm to be adjusted in and out.
Unfortunately that's not an option. I got the photo from Facebook and have asked over there as well. -
So it occurred to me since the car wash I go to includes free vacuuming that I could use the vacuum to suck all of the excess water out of the mirrors. I've tried it a few times and so far it seems to be working good. No more water spot streaks down my doors! There's a seam under the mirrors where the plastic meets the metal which traps water and I have to vacuum that out too. It's an extra hassle to even have to do this but its better than the alternative.
Just a quick update, after being lowered for a couple of weeks, I started hearing random popping sounds coming from the right front, then a day or two later the left side started doing the same thing. I thought something was seriously wrong so I pulled the front tires and inspected everything to make sure nothing was loose. Turns out everything was fine and after some research online I had a good idea that it was the springs rubbing against the rubber seat. So I spent a good three hours pulling the front struts again and putting some grease between the springs and rubber spring seat. It's been about a week and no more noises from the front. Turns out doing this was mentioned in the how-to guide as an optional item. Unfortunately I didn't pay attention to it the first time. I forgot to mention, this time I picked up this oxygen sensor socket from Nothern tool to use on the 21mm nut on the top hat. Although I could only do about a quarter turn at a time It worked good. Performance Tool Oxygen Sensor Socket — 3/8in. Drive, Model# W1267 | Northern Tool
The water drip issue is a huge pain. Just when I think the water is all drained from the mirrors and I've dried off the doors for the final time I'll come out an hour later and there will be a long water spot streak down the sides of the doors. The last thing I want to do is carry a leaf blower around with me every time I go to the car wash lol. Looking under the mirror I can see that most of the water is dripping from the seam where the plastic trim fits around the mirror. I am considering using some clear silicone to seal it up or maybe drill a small hole so it drains quicker.
Locks stopped working
Gregertech replied to BMB's topic in Alarms, Keyless Entry, Locks & Remote Start
Did you ever resolve this? My 19' Edge ST, which I purchased new, started doing the exact same thing after about 18 months of owing it. Only the driver's door consistently locks / unlocks with keyless touch. The other doors work intermittently, but most of the time do not work. Tonight I disconnected the positive terminal on the battery for about and hour and and after reconnecting it I tested the doors and they all work. Time will tell if it continues to work consistently. -
Got the springs installed this weekend. I think it looks really good, (even with the snow tires) more street beast and less 4x4. Overall the install went good, the only issue was with the 21mm nut that holds the strut hat on. I had to find a way to hold the nut and turn the 10 mm on the shock. I ended up using a pair of needle nose vise grips. Thanks for all the info. I'm off to get an alignment done today.
Awesome to hear that the install went well for you. I plan on installing my h&r springs next week and this is the write up I was going to use. https://drive.google.com/file/d/1wQ3WRD6zvzHaAbxE3hCZpyKIwbBI3-Gs/view , from this thread https://www.fordedgeforum.com/topic/22579-hr-sport-springs-on-g2-edge-sport/?page=7 Is this the same one that you used, any issues or tips? Also, can you post some pics from the side and front. I am curious how much the wheels/tires are tucked in due to lowering and if I'll need to use wheel spacers to compensate.
2019 Edge ST amplifier install
Gregertech replied to Beefnuts's topic in Accessories & Modifications
Good informative video. I just wanted to note that there is also a spot on the drivers side firewall, behind and below the battery to run the wire (battery must be removed). I have 1/0 gauge wire running through it to the back. It is important to note that you want to have protection around the wire as it goes through the firewall. I put a hole through the middle of the existing grommet. If the amp wire is laying against the metal hole through the firewall, it could overtime wear through the wire's shielding and eventually come into contact with the metal. This also brings up the importance of making sure the amp wire is properly fused. I have an extensive audio build log over on diymobileaudio.com for those that may be interested. https://www.diymobileaudio.com/threads/2019-ford-edge-st-build.417123/ -
I filled up with 93 octane and installed the LMS performance tune for the first time yesterday and Wow! The ST just wants to go, the traction control light is always flashing and I'm hardly pushing it.
The day is near. I'm just waiting for Livernois to send me the performance tune so I can upload it. ?
Who have you submitted it to? Are you looking to get royalties. Have you looked into crowd sourcing?
This is why somebody needs to find out what it can do. BTW apparently LMS has an updated tune for the ST that is pushing more power.
Congrats! Now somebody needs to do something like this to an ST!
Perfect! Have you done any other mods? What air filters are you using?
