Everything posted by Rimcrim
Yep, mine does this too, and the timing seems random as stated above. I have no idea what it is, but am curious to find out. It does sound like something metal is disengaging or clicking into place.
I want those roof rails and that infotainment screen. I wonder if we could possibly swap parts for the screen, but the roof racks wouldn't work due to the extended wheelbase.
Yeah I was going to do this on my Edge Sport before it got rear ended and written off (while parked), but I don't think this will work on my ST quite the same since they are now vertical cutouts.
Ah, that looks better than I expected, it actually sits into the bumper pretty far. I don't know if it would make much difference adding tips then, apart from looks. I never really liked the stock exhaust housing and wish we just had tips sticking out like the Edge Titanium and Explorer Sport/ST etc. I plasti-dipped mine to get rid of the chrome and it looks better, but still not great.
- 16 replies
- borla exhaust edge st
- edge st borla
- (and 2 more)
I have had this a couple times as well, but not recently.
I had some coming out of my exhaust too, and it's all stock back there. I figured it might be from the resonator, but I saw it happening at around 2000 miles.
Thanks for posting these, it sounds pretty good! I wonder if the sound would change much if you extended the tips so that the exhaust actually came out of the back instead of bouncing around behind the bumper.
- 16 replies
- edge st borla
- (and 2 more)
Curious on this as well. Everything shown so far has been on an Edge Sport, what about the ST? ?
Those look better than I expected. I might order some in Red with Black ST lettering. How hard was the install, and obviously it still brakes the same with them on correct? How close are they to the inside of the rim when they are on? Thanks!
I was simply meaning swapping in the leather pieces where ours are plastic, not the Instrument Cluster. That's a whole other beast.
I wonder if we could order the European dash parts and install them on our Edges, would be a fun project
This is a good idea to test
I think the MRT also ends at the stock location and doesn't stick out, but theirs doesn't seem to drone too bad from the interior video that they posted. If/When I replace my exhaust I will definitely get tips to extend it outside - not really a huge fan of the stock exhaust housing.
Got the chance to drive around a bit after the TSB was performed and I can already tell that the shifting is much better than it was before. Shifts are smoother, it seems to pick the right gear more often, and it even feels quicker in D now than it did before. I always felt D was too lazy and had poor throttle response compared to S but now they are much closer.
Correct, these won't fit the ST.
Congrats, looks great!
Recall order 19B11 - Adaptive Headlamp Software
Rimcrim replied to Tedseed's topic in Recalls, TSBs & Warranty
They definitely come with the 401A Package, not sure about the base ST. -
I would definitely recommend an oil catch can/separator. These are Direct Injection, not Port Injected, so there will be oil vapours coking the back of the intake valves. A ton of us on here use them and the JLT is probably your best bet for the price, quality and ease of use.
Posted in the other thread but it's relevant here too; I had the fix done today and confirmed that it works now. I haven't checked the settings yet to see if the option is there but will do that and report back. What I noticed was odd was that under "Cause" the service department put "19S11AA - Disable Engine Block Heater Cord".
I had the fix applied today and confirmed that they work now. Interestingly, under "Cause" they put "19S11AA - Disable Engine Block Heater Cord". -
Find a new dealer, that's crap. -
Had the dealer perform the TSB today. They took it for a test drive and confirmed shifting issues, the TSB was updated and they confirmed the repair with another test drive. I noticed it was better on my drive home, but that was in traffic for only 20 minutes so haven't really given it a proper test yet, but so far so good.
Yeah I don't know what you expected if you're always flooring it. 17-18mpg in that case seems fine.
Having the TSB performed today, will post an update afterwards.
I'm going to have the TSB performed on Thursday, I'll post my results a couple of days afterwards.
