Dbrennan1780
About Dbrennan1780
Dbrennan1780's Achievements
  1. I heard back from ForScan and here's what they said: This is known issue, but there is no known solution yet, According to the logs, the procedure is interrupted by BdyCM. The error code thrown is B115E:08. According to the workshop manual (1.pdf attached) it means Bus Signal/Message Failure. Recommended pin-point test G (2.pdf attached) does hardware part check, but we think the problem is not in the hardware. We have 2 versions (both not checked yet): 1. New camera may be not fully compatible with old BCM. Most likely, BdyCM or APIM firmware update is necessary. 2. If the camera is not OEM ("clone"), it may be not identical to original (OEM) one. Anyone know how to do the firmware update they are describing?
  2. I didn't know that we could even send logs! Great feedback and appreciate the thinking. The OBD2 scanner that I am using is a Bluetooth one - so there's no cable attached. I did post something to the ForSCAN forum, but didn't get a response hoping I can get this sorted out and get my camera back again!
  3. I have this EXACT same issue. Would be very interested if anyone has found a solution.
