Deanf
About Deanf
839 profile views
  • Haz
Deanf's Achievements
  1. I have a 2014 ford edge sel with the 4” display. I removed the whole radio and climate control and replaced it with an android touch screen. I’m trying to get the back up camera working. The android radio came with a plug that connects to one of the plugs in the dash, that outputs to an rca plug, which plugs into the new radio. I have a video signal when I put it in reverse but it’s white static. I’m guessing it’s because I need to send 12v to the camera. Does anyone know which wire is the power wire for the cam? Might as well also ask which one is the ground as well. any help would be greatly appreciated. TIA Dean
  2. How do I know if i need to replace the strut mounts when I do my strut job. (2014 edge SEL) Is it a good idea to just replace the mounts so I know they are new? If I could find an OEM motorcraft quick strut, I would just do that
  3. Yeah, I have done the whole spring compression on an old '88 pontiac 6000 when i was in collage. It's not horrible and I can do it, i just wanted to get it done fast. I figured that if i get a quick strut, everything is new. If I could find a motorcraft quick strut for my car, I would probably just do that. My main concern is that I don't want to go stiffer than OEM when all is said and done. That being said, maybe my best bet is to get morotcraft strut and a spring compressor. I am wondering if I decide to just replace the strut and use all the other parts, is it a good idea to replace anything else? the upper mount, dust covers, bumpers ect. I wish I knew more. lol
  4. Hi, I have a 2014 Edge SEL and it needs new shocks and struts. I was on RA and settled on KYB strut plus (with the springs). I'm wondering if I put Motorcraft shocks in the back, will it feel weird, or do you think it will be ok? I read that the KYB's are a little more stiff than OEM. I also read someone having a concern that getting the pre assembled kits for the struts could change the height from OEM. Any thoughts on that? I dont need the new springs, but I am just trying to get the job done fast and not mess with the spring compressors TIA Dean
  5. Im upgrading my crappy stock speakers in the doors and am trying to figure out what wire is positive on all the speakers. I also want to add a sub to the system, Not sure if I can on the factory radio. Does anyone have any advice or a pin-out diagram of the radio? TIA!! Dean
  6. Metra makes an aftermarket installation harness. Give Crutchfield a call. They can explain the options you have ans what functionality you will lose, if any.
