Arebeeem2
About Arebeeem2
Arebeeem2's Achievements
  1. To the OP. Did you resolve the ride issue with the 22" wheels? I'm considering them for my SEL, 2007. Thanks
  2. Thanks!! I found a fender! Where is the best place to post my question about the front body clip "swapability" from 1st gen to 1.5 refresh?
  3. Soooo. I did get the Edge to start and run. Waited so I didn't melt the cats. Restarted and the engine ran like a v-twin (not in a good way) :-) MIL popped a code P0351. Unfortunately the car is remotely located so I don't get to it easily nor everyday. I replaced all plugs and coils with brand new before I installed the repaired PCM. I haven't tested the #1 coil yet, but I'm trying to see if there are others who have experienced this after doing the plug-coil-PCM repair? Not sure if this is the correct place to post, but I'm also looking for body parts (ds fender and front ds door).Maybe someone can tell me if the 1.5 freshen front end will bolt onto the 1st gen?(I really like the freshened front!)
  4. Thanks for the replies. It was fuse 34 in the underhood box. It's funny because I know that I had checked every fuse.
  5. Hello forum! Glad to have found this spot. I have a 2007 Ford Edge that I purchased a few months ago that had burnt coils. I replaced the coils plugs and had the PCM repaired and the vehicle still refuses to start. It will turn over but will not start. I have checked the fuel and fuel pressure and it is good. I have tested power and signal to the coils and there is no power to the coils. Can someone give me the next steps for my diagnosis? Any and all help is sincerely sincerely appreciated.
