jamesedwards98
Everything posted by jamesedwards98
  1. I appreciate the responses. As you suggested enigma-2 the first place I went looking was the switches. I have located the problem. The motors are both fine, the reason there was no response was that they were disconnected at the switch intentionally, the harness was unplugged from the switch. When I reconnected the harness at the switch the shades opened without a problem. The glass then opened just fine, which made me question why it would have been disconnected? I then located the actual problem - when I tried to close the glass it did not move. The 2 slides that the glass panel are attached to in the front which push and pull the glass panel have broken off, both sides are completely separated. Does anyone know if these are replaceable? I located a part number - 7T4Z78502M78A - that seems to be it but not sure.
  2. Appreciate the suggestions, going to try disconnecting the power/initializing today and if that has no effect I will go ahead and order both motors.
  3. Hello, new user and Edge owner. I just purchased a 2008 Edge Limited. I apologize if this is covered elsewhere and I missed it. I have the Vista roof and when I purchased the vehicle it was not functioning, neither the glass or the shade give any response. They are both in the full closed position. Does anyone have a step by step troubleshooting guide for these roofs? I have check the fuses in location 17 and 18 in each box and both seem to be good. Is it common for both motors to have failed? Is there a way to test the motors? Is it possible it is the switch? Any help is greatly appreciated. Thank you
