SMR2818
About SMR2818
  1. Getting a rattle noise on the door panel for both front doors, only happens when driving over rough road and stops when I press lightly where the arrow is pointing. Any ideas for a solution?
  2. Updated to build 20282 on a 2019 Titanium and album art for Sirius isn't displaying, tried refreshing and still not displaying the album art. Anyway to fix this?
  3. Planning on going on a trip in the next couple weeks that is 900 miles there and 900 back. Oil monitor is showing %50 at 43,872 and my last oil change was done at 42,832 miles with Valvoline MaxLife. Should I get an oil change now or am I ok to wait till after the trip?
  4. Anyway to disable iTunes tagging on Sirius XM or to make it so that the text isn't a hard to read grey text? I have tried updating the firmware to the latest version but it hasn't helped.
  5. I am looking to install a Kenwood KSC-SW11 underneath the driver side rear seat on a 2014 SEL, where should I hide the wires and where can I run the yellow power wire through the firewall to the battery or how can I connect it to the interior fuse box if I decide to get power from there?
  6. Bought a 750 CCA battery and all my problems have been solved!! Thanks for everyone's help!
  7. Battery is only 3 years old and it is holding a charge, still getting the same symptoms with the radio removed. Same symptoms happen just by opening the driver door with no key in the ignition, interior lights and the door keypad light flashes and instrument panel clicks and the gauge needles woble a little and this happens with each click but then stops when the headlamp exit delay time is reached.
  8. I have installed a aftermarket double din radio in a 2014 Ford Edge SEL and now the car will not start but before install was working fine, radio works properly in the accessory key position but when trying to start the car the engine turns over but will not start and the instrument cluster makes clicking noises, battery was tested to be good at the parts store and the car has less than 40,000 miles on it, harness connections were also double checked. Anyone know what the cause could be? Do I need to get a stronger battery than the 540 cold crank amp battery I currently have? Pioneer AVH-4201NEX (using no amp) Metra 99-5829CH Dash Kit (to keep MyFord 4.3" screen) iDatalink Maestro RR (flashed with ADS-RR(SR)-FOR02-DS (512) (2.7) ) HRN-RR-FO2 Factory Integration Adapter Harness
  9. I have a 14 Edge SEL, when I use the windshield washers the driver side over sprays a little onto the driver side window. Is there a way to adjust the strength of the spray or to aim the nozzles?
