mustangelite
About mustangelite
mustangelite's Achievements
  1. Would just like to get a little info on the sizes wire colors as well as what speakers you think would be best..... you see, any little tidbits would help. Thanks in advance!
  2. I bought the adapter the you attach to the ACC Port in the fuse box, I believe the guy said it was either fuses 90,92 or 93, after I pull the 10 amp fuse I add the adapter in it's stead, then replace the old fuse back on top, do I need to add the second fuse to the top? The main power wire to the battery has a big red fuse built in as well....ALMOST DONE!!! We've been getting some hellacious rain down here in Florida so I'm eager to get this done and over with
  3. Honest to God from the bottom of my heart Guys thank you so very much!
  4. Seeing conflicting wire info for what the specific color wires, of both drivers side and passenger side turn signal wires to tap, secondly, the white wire on the drivers side has to plug into the ACC?? Going to sit and watch some more video after I get home from work. So all is done, asside from knowing what turn signal wire colors to tap out of the 3 choices on each, and where to put this white ACC wire, thank again, pretty cool forum, hopefully I can post pics
  5. Just Purchased a set of aftermarket Led/turn signal DRL's from China, have it almost all wired up, but it wants me to tap the new drl's (orange) wire, onto the drivers side turn signal wire, then I have to attatch the power wire and ground onto the battery. The passenger side, I have run the yellow turn signal power wire over that side to tap into that turn signals "power" signal. Each side is hooked up to a main control unit that connects it all to the new DRL's themselves. However, I am leaving the driver and passenger side (white) wires inoperable as they require being hooked up to the headlights and lower the LED's power consumption by 50% or so during the day. My question is, will I be alright leaving these white wires unused, and what (vehicle side)color wires do I need to tap into for the turn signal synch of our 2011 Ford edge Limited?? Thanks so much and I will add some pictures if I can!
