ash042679
About ash042679
222 profile views
ash042679's Achievements
  1. thanks so much. I will start with the blend door motor located by the glove box , it seems easily accessible. I believe there are few more other than this one, but hopefully this is the one. is there also one on the drivers side ? will keep everyone updated
  2. enigma - 2 I ran the test you mentioned. looks like I have an error code A2 6E those were the results. anywhere I can find what these codes mean?
  3. I will run that test. I will also review the fuses. I will try to find a diagram online for the fuses relates to the hvac. not sure where I placed the manual for the edge. thanks in advance
  4. any chance it could be the actuators? looks like there may be a few of them in the system
  5. I was using the OBDLink MX , didn't show any codes. Haven't tinkered with it just yet, but just noticed it won't switch to any other settings. Whether I want floor only, or whatever other setting it is just stuck on the combination of floor and main vents ... Frustrating , considering the temp controls work .... More worried in the winter when I need the windshield defrosted than I am now
  6. Thanks I will review ; ran a diagnostic wit my OBD 2 tool not showing any error codes ; I will review the document.
  7. One more thing I noticed , both on the control unit that was in the car and the second one I put it , once I hit the front defroster button , the small light on the control unit turned on, and no matter what other button I would hit , that windshield defroster light stayed on ... Maybe I should try to leave the battery disconnected for a while
  8. I did actually ; didn't have any luck ... should I leave it disconnected for a while so everything resets?
  9. Good Evening All, I have a 2008 Ford Edge , Dual Climate Control ... Here's my issue - I am able to change temperature up and down, works flawlessly ... The problem is that the air is stuck flowing thru the front vents and floor, it will not change. I have tried to set onto the windshield it won't work , tried to set to just the floor and it still blows thru the front vents and floor, its essentially stuck in that position. I originally thought it may have been the control unit , ran up to the car yard and grabbed another unit, installed and same issues . I am somewhat perplexed. As mentioned, I can adjust the temp settings , but the flow of air is stuck... any thoughts? possibly the actuators? any insight would be greatly appreciated.
