Everything posted by snmjim
Would 50cc more allow e85?...
Thanks for your support & encouragement Xtra but it does get crazier... We were limping at the track due to top end breakup caused by a o2 sensor that was going bad and eventually went bad after the first run which in turn set off the nannies to protect the motor of which the ECU started pulling back power on the last 2 runs and we still pulled those speeds & times... The hybrid Turbos performed way better than we could have imagined, providing lots of boost!!! Up to this point we and the Tuners were very frustrated with the complexity and depth of the Tune tables for this platform however after the top end breakup at the track and some other potential Tuning scenarios that could have ended in catastrophic engine failure we have come to realize the rational for this complex Tune program/tables, Ford programmed in a large amount of motor protection. Therefore thank you Ford... To be continued after an o2 sensor replacement, more Tune Revs, Dyno time then off to a warmer track or wait for Spring... BTW, she's still a great daily driver with climbing mileage!
We ended up fabricating our own from scratch using our HPTuner software to measure & substantiate gains. The short of it is if your going to use the stock snorkel entry point through the front cross member you will NOT make any measurable gains. Hint: you MUST have a larger than stock or multiple fresh air entry points into the air box...yes, we've tested & measured to validate this statement...?
Sorry it's been a year plus since we promised to post a track slip and Dyno sheet however after multiple scheduling and Tuner set backs we did manage to get a few runs in on the last night of the season. Car #69... Notes: - Due to a bad o2 sensor we weren't at 100% which caused high end breakup but we can promise an improved showing at the next opportunity of which we'll update this this post with. - Dyno sheet will also be posted here once we can squeeze into one of our sponsors Dynos schedules... Thnx @zfgracing Watch Ford Edge Sport Record Quater mile (12.29): https://youtu.be/ZwkMhzYebAE
Duplicate, Ref next post...
From the album: SNMJim
On page one of this topic string and about the 22nd entry down by me will provide all the pricing and contact Info necessary. These are being produced by a custom fabricator (Zury) If your unable to contact Zury (fabricator) with the Info provided on page one then PM me and I'll reach out to him personally...???
Here's the answer to all of your 20" wheel issues, these wheels, tires (All-Season Performance) & TPMS sensors were all new and only have 500 Hwy miles! Make me an offer I can't refuse so I can use my garage again before winter gets here...lol...
Based on general engineering knowledge and a gear head to boot, I wouldn't even give a second thought to attempting a 4 Cyl gasoline engine tow trip of that capacity and would be reluctant with a tow package...of course unless it was a diesel...wish you well...?
Haven't noted any mention on this forum. Besides if your not Tuning the majority of engine Mods will not have a significant benefit until the Tune is modified to know it's there and tweaked to take full advantage of it...
It's not required but if your changing the T-Stat to run cooler then you should be aware that the fans & AGS operate in conjunction with that and to optimize your intent to run cooler you may want to consider adjusting the settings for the fans & AGS...
Rear Motor Mount (RMM) (2016 Edge Sport)
snmjim replied to snmjim's topic in Accessories & Modifications
No one on FEF that we're aware of and if you did you'd first have to ID the Duro rating of the stock bushing and use an equivalent or else your wasting your time & money. The front mount is fine for stock & so far for up to 500 whp and resonably easy to access for your average gear head. So if your not interested in giving your Edge an Edge and the stock mounts are proving fine with higher performance then I'm not getting your concern... -
4 posts before this one will answer what's slowed things down. However, Special_K has made several data point posts of what we've identified so far and more to come as we progress. Note: This is a hobby for us, we both have full time careers...
For those that expressed concern and/or interest about the minor rear hit we took recently here are some Pics of what we found once the rear body panel was removed...absolutely nothing, GREAT for us but sucks for the Acura... Should have the car back sometime this Wk then back to wrapping up the 93 Tune and on to the E?? whatever we can achieve Tune... Yes, we're quite aware that we don't blur out the tag and that's because the few of you who can get to us should be able to get to us, go figure...
Intercooler Grill & AGS (2016 Sport)
Traction Bump... -
.065 and idk weight. You would have to contact Zury Fabrications for pricing...?? Contact Info & DP pricing is in this topic string
Short of me helping U with the logistics of a trip here for a day or 2 I'd recommend U call Zury and find out where my car and original pipes can help.
Where are you located? What year & model is your Edge? If you live a reasonable distance I can help out by providing him with what he needs using my original parts & car if necessary.
Yes that is the Cat back to the muffler section, contact Zury for the cost. Many of us would probably appreciate a sound clip if you do this with the MRT mufflers. The contact Info is 13-14 posts back from this one, Zury Fabrications...???
BCB Checkout the Special_K specifics in the Tuning section...???
We have no regrets with the DPs & exhaust. The sound is progressively changing to a preferred tone due to the additional pressure from both the catless DPs & modified Turbos slowly blowing out the stock muffler. It will be interesting to see where we end up Tune wise...lol
All's well and no harm. The outcome was minimal thanks 2 some preempted measures and a well placed heavy duty tow hitch...????
