snmjim
    55
Everything posted by snmjim
  1. No, that was strictly just the removal of the resonator and leaving the remainder of the exhaust Sys stock... If you elect to remove the resonator and change the muffler I'd appreciate a review of the end result with sound sample and what muffler you went with... Reminder: if you elect to change out the muffler as well beware of highway cruising tone, with some mufflers it can be very obnoxious after a while. We operate by the concept of "value added for effort & capital expended" therefore on that note why change the muffler when we had it verified that the stock muffler isn't creating any significant restrictions and flows quit well for stock???
  2. If your issue is with the RMM then your answer may be here: http://www.fordedgeforum.com/topic/23572-rear-motor-mount-rmm-2016-edge-sport/
  3. How about let's see some DAs under 500 and a hole in my schedule that coincides with the only two days of the Wk we're allowed to use the track...
  4. Will they fit the 2016 Sport? If so how much would you want?
  5. Great Reco guys! They look better than any I've seen so far and the install went good as well. The rears required a little strong arming but if you start with the center screw and loose fit it until the top & bottom are in all goes well. Ref Pics but pardon the dirt, due for a wash...;-)
  6. Root & Randy, did your package say they were for a BMW? If you have the paperwork that came with them still can you please send me a copy via PM please.
  7. As long as yours don't I should be safe...;-)
  8. We still have HPFP, Downpipes & high volume CAI to go which will be another 50-75 whp after tuning... Then what comes next is a mystery..
  9. Great way of putting it into perspective Brother! Thnx for the numbers...;-)
  10. Hey there Root, If you have some to spare I could use a set please...;-)
  11. Xtra, Anxiously standing by for your Eval...
  12. Root, I anxiously await your Eval so I can make a purchase determination. Here's the link for those interested in this source vise the one I provided earlier in this topic string: BTW, both paddle manufacturers being discussed here are Savanini. Paddle shifters Edge: https://m.aliexpress.com/wholesale/Paddle-shifters-edge.html?channel=direct&keywords=Paddle-shifters-edge
  13. Here's the link: Shifter paddle extesions: https://m.ebay.com/itm/Red-Alloy-Steering-Wheel-DSG-Paddle-Extension-Shifters-For-Ford-Edge-15-2016/163108342421?_mwBanner=1&ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F0%2F0%2F0%3Fmpre%3Dhttps%253A%252F%252Fwww.ebay.com%252Fulk%252Fitm%252F163108342421%26rvr_id%3D0%26rvr_ts%3D963e7fbd1650abc02d834729ffde7658&ul_noapp=true
  14. Yeah, at about the same time & event we had the same noise and found it after several of us violently shook the rear of the car from left to right. And it was..... Wait for it.... The exhaust pipe sashaying left & right usually when going over uneven bumps i.e. speed bumps at an angle. The curved section of the tail pipes where they exit the muffler were clapping against my tow hitch framing. Therefore, we used a body panel hammer (square head) to beat the inside of the tailpipe curvature slightly flatter than it normally is and BAM sound gone. For those without a hitch...hopefully this provided some food for thought...;-)
  15. Just as good if not better...in some cases...lol
  16. Don't recall however, to keep my senility factor in check can you please direct me to where I stated "Sure" so I can also get a reality check? BTW, I reviewed the edits/updates, apparently twice now, and they're definitely beneficial. I'm adding this one to my library of supporting Tech Docs, good job...???
  17. Hey there Root! I'd really appreciate that Do It Yourself (DIY) instruction at your earliest opportunity along with a purchase link. Thanks for running this ball across the goal Brother...????
  18. Looking Fwd to your write up with Pics & DIY details hopefully...;-)
  19. Appreciate your efforts but that doesn't qualify as the DIY we were looking Fwd to. Also its unclear what you did and that appeared to apply for the fronts, what about the rears. Not trying to bust you out here however there's a few of us counting on your write up so we can make a purchase decsion...;-)
