snmjim
    55
3 Followers
About snmjim
7,339 profile views
snmjim's Achievements
  • Very Popular Rare
Recent Badges
  1. When doing a brake job, wether big or small we always recommend a full fluid flush, can't go wrong there...??? Note: brake fluid is one of the highest moisture absorbing fluids which in turn leads to caliper, wheel cylinder & master Cyl corrosion and/or seizing.
  2. Get an electronic copy of the factory service manual, it's awesome, best I've ever seen!
  3. Just the tips welded directly to the stock muffler. Our exhaust Sys is 2.5 from the stage 5 Turbos back to just after the rear Diff directly to the cutouts then after the cutouts its the stock muffler, so that worked fine. Don't know where they came from, our fabricator ordered them. Google Corsa quad tip then select the shopping tab.
  4. Ramfab will point you in the right direction as to who he sold the rights to...?
  5. We sure did! In the first 4 hrs on the market 6 people showed interest and 4 people came to see it. In 10 hrs it sold. No experience hollowing downpipes because we wanted 2.5 pipe all the way back. However, hollowing out the stock downpipes has potential. FYI We have a set in great condition for sale.
  6. Pics available upon request. Misc stock 2016 Ford Edge Sport Parts (slightly used) - Air filter box with new filter - HPFP - Fuel injector manifolds - HPFP to injector manifold fuel lines - All Turbo oil & coolant lines - Intake - Throttle body - Valve cover Oil fill plug - Front wheel small splash flap - Turbo heat shields - Downpipes - Pair of rebuilt heads PM us on Instagram if interested.
  7. Recommend running 2.5 pipe straight off your DPs using V-Band clamps straight N2 the stock muffler with no resonator along with BT cutouts just B4 the muffler. U can setup the BT cutouts 2 work from 2 of the 3 garage door buttons on your visor, one button 2 open and one 2 close...?
  8. Hey there Bryan, Glad to see your build is evolving nicely. In reference to your Turbos...please reference our Insta PM to you...?
  9. If our fully bolted 584 whp 2016 Edge Sport doesn't sell as is in the next 1-2 months we'll be returning the car to stock and selling all the performance parts which will include catless downpipes, maxed out Turbos by CRP, pinned rear coupler and much more. Check us out on Instagram at fastest_edge
  10. Thnx best coast Brother for your kind words of appreciation & recognition. Just want to reassure everyone that we're not gone and can be reached via the forums and Instagram PM systems. Stay tuned on our projects progress via Instagram @ fastest_edge Across the ground or falling from the sky, everything at terminal velocity & beyond???
  11. . Thank You Manu for your support!
  12. Well here's your lucky opportunity, it just went on the market, make us an offer you just might be surprised! it's fully bolted with a stock 3.0 TT eco boost and everything in the car is in pristine condition and a fully functional reliable daily driver...???  584 whp & 600+ lbs of AWD torque and continues to get 29 +/- mpg Hwy cruising at 65-70 mph...???
