JSchneid
About JSchneid
JSchneid's Achievements
  1. Mine was fixed by replacing F2GZ-9D289-ATube Assembly - Fuel Vapor Separator https://www.facebook.com/100007531833185/videos/213905687830886/
  2. my 2017 edge with the 2.0L engine would intermittently do this: https://www.flickr.com/photos/jmschneid/52772338189 The hesitation and rough running is because of the vacuum leak created by the vapor/fuel separator valve being stuck open. when it is making the noise, stop, leave engine running and check your fuel door.
  3. Your engine is leaking water into cylinder 3. This is a common problem with the 2.0 Ecoboost engine. The dealer will replace the entire engine. You will be provided with a loaner car because this will take quite a long time. Here is the TSB for this problem. https://static.nhtsa.gov/odi/tsbs/2019/MC-10169807-0001.pdf
  4. I don't have any info that would help but I wanted to remind you that the transmission in the 2019 EDGE is the new 8-speed transmission. Someones experience with older transmissions may not be applicable to yours.
  5. Use Top Tier gas. https://www.toptiergas.com/
  6. Great that it is covered. You must have an extended warranty because a 2009 would have expired long ago.
  7. I have a 2016 Titanium 2.0L AWD. It only has 8000 miles and it has had a PTU seal leak. I believe this is common and in my case the dealer installed a newer style seal under warranty. My PTU has a drain plug, I believe all PTU's in 2016 and newer EDGE's have the drain plug which makes fluid changes much easer. Images of leaking seal and newer style replacement seal
  8. I have seen the same thing on MACT Ford Edge facebookpage. Same response from dealers.https://www.facebook.com/photo.php?fbid=1678940345533312&set=gm.515941378802222&type=3&theater&ifg=1
  9. I would encourage anyone with a Gen 2 EDGE (2015 - present) to look at the PTU seal for the right front wheel drive. Some of the original seals were defective or fail prematurly. This condition may only be on units with the 2.0L engine. My 2016 failed early, sometime before 7000 miles. The photos show the unit leaking, after repair and the parts used.
  10. I very much doubt that I would have any info to help you with your question. Unless, seeing the differences in my PTU, air scoop & fins cast into housing provided any new helpful info. I found my PTU completely different than any I have seen photos of previously. I was curious as to what you had in your 2016 Sport looked anything like mine.
  11. On your 2016 Sport AWD, what does your PTU look like? Does it have a drain plug, fins cast in housing and scoop in shield beneath engine directing air on PTU? These photos are of my 2016 Titanium 2.0L PTU which is much different than photos of other PTU's I have seen.
  12. I usually buy Shell, a Top Tier gas, at a quick mart close to home. Because of this article, I stopped at a Valero and saw this sticker for the first time.
  13. How are you transfering the Royal Purple to your PTU, pump used etc?
