Everything posted by Xtra
I started to cut out the parts and this is the first of three cuts. It is the first time I have used the jigs other than when I built and tested them on the prototype. I hope the other two jigs work as good as this first one...
Thanks
I was not able to show exactly how it is installed because I had to hold the camera . It is an easy enough install, but using both hands is necessary. At least you get a view of the V3 and Adaptor installed in my Sport.
Things have changed form the time I made this video and it is no longer valid . Thus it is gone
Things have changed form the time I made the video and it is no longer valid . Thus it is gone.
As promised the plastic shop came through with the C-Clips. I now have all the parts necessary in stock to complete 4 Adaptors. The long strips are the J-Hooks and the Tabs. They are made in a strip then chopped to size. Here are the CNC machined C-Clips. They look much better than the prototypes.
Just came back from the plastic shop with some of the parts. The molding went great on these first 4 units. The J-Hooks are done. They are made in a long strip then cut to size. You can see how much better the parts look having them CNC. The C-Clips needed some adjustment as they were too precise and the fit is wee-bit too tight. I should be able to pick up the improved ones tomorrow afternoon. These are the first four V3 that will be available to members.
Xtra replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I just received a letter from a California law firm. The 2015-2018 Edge, 2017-2019 Escape, and 2017 - 2019 Fusion 1.5L and 2.0L Ecoboost can have a defect that can cause coolant loss, white exhaust smoke, misfires, check engine light, and engine overheating. If you have had two trips to the Ford dealer to fix the problem you may be entitled to a complete refund of the money you originally paid for the car!!! This is only possible because of California's Lemon Law. I had no idea that there was even a problem with these cars. I love my EcoBoost. -
Those should work well. I have used similar air bags before when I towed a boat with one of my past cars. I ran an air hose between them and filled them both from one tire type valve that was mounted below the bumper. It worked well and towed much better . I was able to level the ride and keep the headlights on the ground, as before they pointed up at the sky. I also used a clip-on towing mirror for the drivers side. For $100 you can’t go wrong ?. -
BUMP... That video was so bad... lol ? had to take it down..
The plastic shop is going to CNC the clips and latches. This should speed up assembly and the parts should look much better than the hand made prototypes. They are also going to mold 4 V3 to get started. I am using this run to determine the price. I am trying to be price competitive with major manufactures and offer a better product at a better price.
Comparison of stock and V3 . The V3 can move much more air with less restriction than OEM, and offers both dry disposable and wet/oiled washable filters. Replacement filters are available online and just a click away..
There’s 5 Black ABS and 4 Carbon Fiber V2 available.
I am sitting on what is left of what could be the last run of V2s that there may ever be. It is looking like everyone who wanted a V2 has one. As I cannot afford to do a run for only one order these very well may be the last V2s to be made. This is especially true of the Carbon Fiber ones. The only way I would do another run is if there was enough demand. And demand is very low right now. In the future, unless the demand picks up and I can do a run, I can and will make one V2 at a time but . ..The cost of set up $65, and loss of group pricing, will drive up the price of making one at a time. So I can say with confidence that you will never see prices this low on the V2 ever again. If you are thinking about getting a V2 then best to act now. I am not a salesman. This is not a gimmick. It is just how things are right now. I am telling you all this because I want the V3 project to be realized, and it has stalled out just when it was ready for production. I thank everyone again for you support. PM me if you want one of possibly the last V2.
There are still V2 available from a run I did back at the end of February . I tied up hundreds of dollars in the CF material and hundreds more vacuum forming them. I need to sell them to recover. the investment. The $15 off represents the pure profit I make on them. The rest of the mark up on them is to cover expendables. The plastic shop needs to be paid for the V3 I ordered and I am short. I have to sell at least one V2 to cover the difference. If I did not have this V3 project everything would be cool ?, but I am stressed and have over extended myself. If I cannot sell at least one V2 the V3 project will stall out . Someone please step and get a great deal and help launch the V3. I am so desperate that the next person to buy a V2 will receive a very special discount on the V3 . I thank you all for your support.
Dead Battery on new Edge ST
Xtra replied to ALDriver's topic in Alarms, Keyless Entry, Locks & Remote Start
New cars like the Edge have lots of energy vampires. Systems that run even when the car is turned off. These parasitic vampires take a toll on damaged and marginalized batteries that have just enough CCA and reserve to do the job. -
I bought a 2016 Sport new and went through 3 batteries in 3 years. I got tired of it and bought a larger H7 size battery and have had no problems for over 2 years now. They do make an H8 that will fit, but it is big, heavy and overkill unless you live where it is freezing a lot and / or your car has auto stop and start. Because the battery sits up high in the Edge and weight affects the handling, I think that the stock ST battery might be the same small battery that they used in the Sport. I have found the H7 size to be the best comprise between weight and reliability. -
The plastic shop is also going to make a part I call the "J-Hook". The J-Hook is the part that the OEM Air Box clips onto. This is the prototype J-Hook. I made several versions of this attachment point before settling on the J-Hook design. You can see a different version at the bottom of the photo that required a lot of milling. I call it the J-Hook because of it's shape. I sure made a big mess with that glue didn't I? lol. It is a simple yet effective design..
I am having a batch of four V3s molded, and they are available. PM if interested. The V3 fits both the 2.7 EB Sport and ST. The V3 will include: 1. The V3 Adaptor 2. Clamps 3. Two Aluminum Elbow Reducers 4. Lid with Custom Sensor Mount 5. Sensor 6. Gasket 7. Your choice of washable reusable Wet Filter or disposable Dry Filter. Replacement filters are also available on line. 8. Detailed Install Instructions Optional: AUX Air Intake with modded lid, flex Hose and clamps. Basic install of the V3 1. Remove the OEM air filter disconnect the sensor and remove the Air Box lid from the car. 2. Snap the V3 onto the OEM Air Box 3. Hook up the two Elbow Reducers to the cars accordion hose 4. Plug back in the sensor
Just had a meeting with the plastic shop about doing some CNC work on the V3. This is what I use to call the gate, now I call it the "C-Clip" because of it's shape After a few attempts at milling on my drill press I was not satisfied with the results. You can see in the photo below how the holes are not even or perfect ovals. Decided to have the plastic shop make the complete C-Clip for me. It will be made on a CNC machine and add to the price a little, but as this part can be seen when the V3 is installed it is important for it to look good.
I am amazed that what appears to be such little damage would be considered enough to scrap such a nice car. I am sorry for your loss and the inconvenience. I hope that you find a nice equivalent replacement soon. Hmmm ... Just dreaming, after all it is a Sport ..... Buy it from the insurance company for pennies on the dollar as scrap, then gut and strip over 1,000 pounds out of it. Put in some H&R springs, tune it, drop in some light weight race seats and keep the outside stock. Hang on!!! -
One more side is complete one to go. Added these three blocks for the OEM Air Box to catch on. They are way more precision than the proof of concept ones on the white prototype. They have only 0.1 for clearance or 0.050 per side. I modded the cut off top of a OEM air box to use as a jig. Yes, I bought a OEM air box and then cut it into pieces. I still have one more side that needs attention.
Today I worked on the gate ( for lack of a better word ) . No jigs were needed for this step as the gate self aligns on the lid tabs . Here the gate is welded into place. With the gate installed, the lid can be clipped onto the V3 Adaptor. Added a 1/4 inch layer to the top of the gate to help hold the tabs on the lid. Here you can see how the gate is "C " shaped in order to clear the edge protector.The 1/4 inch layer over the lid tabs can also be seen in this photo. The gate is much smaller and cleaner than the first prototype. It fits much better and no rivets are necessary. Next step is to work on attaching the Adaptor to the 'OEM air box.
