er65nsunny
    2
About er65nsunny
er65nsunny's Achievements
  1. You should be able to purchase it from a local Ford dealer. I did a search for the number that was on the harness but it doesn't come up, Ford must have a different number that they go by.
  2. I purchased the unit off Ebay you also need the amp, as long as the unit comes out of a Ford unless you want the Lincoln or Mercury flashscreen to show when the radio starts up. Model # doesn't matter, yes the wiring harnesses are the same for the 2008 thru 2010 models as long as both have factory navigation the unit plugs right in. I reprogrammed the unit myself both sync and steering wheel functions all work and I even installed a backup camera as seen in pictures. I first checked with our local Ford dealer and they told me it was not posible to do but it is posible if you know how to do it. You have to program the unit when it is installed in the vehicle.
  3. Yes a 2009 navigation unit will work in a 2008. the unit has to be programmed to work in the 2008. I installed one in our 2008
  4. It should pull right off. I've had mine off a few times without any problems.
  5. Remove the four screws for the handles on the bottom panel. Then just pull the panel towards you starting at one corner it will pull right off.
  6. Yes I had to remove the rear hatch interior panel and ran the wires on the passenger side. I just removed the door weatherstrip along the top and pushed the wires into the headliner. I also removed the passenger side front pillar moulding and ran the wires to the radio. I purchased the camera harness for the Lockpick which plugs iinto the radio unit.
  7. So far it seems to be working great. The vehicle health report wasn't working and I could not figure out why until I checked the Lockpick website and saw they had an update which fixed the problem.
  8. There is a Ford rear view camera listed on Ebay # 130478016599 That says it has the sync mic on top for $150.
  9. If you go to Accessories & Modifications and search gauge.
  10. Yes I had the same problem so I changed mine to the black faces.
  11. I was wondering if you are getting rid of any of the wiring harnesses from the Edge.
  12. I added this to our 2008 Edge follow the link and look fo er65nsunny http://www.fordedgeforum.com/index.php?/topic/2710-2009-factory-sony-nav-system/ and this link for the camera http://www.fordedgeforum.com/index.php?/topic/2768-backup-camera-install-into-factory-nav-unit/page__st__20
  13. You could but you would have to change all the leds if you know how to solder, I believe someone on the fusion forum did it to their Ford Fusion.
  14. You wouldn't be able to take a picture of it would you. I would apreciate it.
