Dymes
Everything posted by Dymes
Factory Sirius Sat Tuner P/N 2007
Dymes replied to klc317's topic in Audio, Backup, Navigation & SYNC
Remove the back scuff plate around the trunk latch by pulling up ur S/N will be on left side on silver box that the sat module. -
HID with daylight running lights
Dymes replied to fordforever41's topic in Interior, A.C., Heat, Interior Trim
Sorry for the delay in responding. It took me about an hour to set up everything. Steps 1 Peel off the the tape from head light wires so they are is only the 2 wires about 12ins retape them back up as headlight wires only. 2 The wires should now reach the fog lights an plug them in !!! ( tape up passenger side original fog light wire nolonger need) 3 On the drivers side take original fog light plug an plug it in to relay harness (U only need one connection for harness) 4 Connect relay harness to to HID ballast left side an right side an connect bulbs in to headlights. 5 Relay harness needs to be grounded my harness had ground wire on left side an right side an then connect positive to the battery !! That's it really, now with switch in auto an pulled out your light will work as fog light runnig light during the day an at nite your HID will auto, come on !! will try an get some pic this weekend.. -
I have HID head light in my edge I went a little different way with mine.I switched my headlight plug in with my fog lights so now I have silverstars bulbs in my fog light lens an come on as my running light DRL during the day.I leave my switch in auto spot with fog lights on so when it gets dark headlights come on automatically.So now during the day no headlight just fogs.HID work great no flickering still use relay harness.Neg.. to this App when you turn on high beam low beam turn off (like fogs would) but now your fog lights stay on now because they are the low beam..I have 8000k HID so I really never use high beam.... hope that makes sence !!!!! -
Mustang maybe MKX not likely heard they cann't fit the turbo set up in ? <_<
At work they are calling it the 2010.5 we start building them in feb maybe.
I also have seen the new edge an mkx .I heard that there will be a 2.5 ecoboost engine an regular 3.5.Mkx will also have a 3.7 offered no ecoboost
I call Navteq said I can get a disc for a great price of only $249cdn told them to keep it
A friend had problems with his lift gate took it to dealer an realized he was missing a rubber stopper on the lift gate causing uneven presure went it came down on.Not sure this applies to anyone
"Plastichrome" fog light bezel
Dymes replied to BlazedUp's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Edge sport has black ones depending on front bumper you may not notice. -
2008 Edge Navigation/GPS Antenna Reception
Dymes replied to Bonzo84's topic in Audio, Backup, Navigation & SYNC
I have the same problems sometimes I don't think theres a real fix for it <_< -
That center cap can be changed.
"Plastichrome" Fog light bezel.
had my 08 bezels changed cover under warr'n -
2009 Ford Edge Navigation - Software Updates
Dymes replied to ebaker21's topic in Audio, Backup, Navigation & SYNC
Yes the head unit is now a Sony but like sync I think you need to download updates for it -
I'm use a 7p copy now an it works fine 8p will work on your edge don't let them tell you differently....
If you jusy got your edge you should talk to the dealer about current disc because if 6p is what you have that already 2yrs old 8p was at the end of May....
make sure they get you the new 8p nav disc with deal...
Navteq has 8P back on sale an in stock !!
On my Nav deck if you hold down 3-6 at the same time it will do a speaker test an walk through each one.Not sure if that helps you at all ?
To second what Lex said I have a 08 nav limited, I've had BT connected as a mp3 player plus usb stick on 1 an 2 an my headrest DVD player connected to line in had no problem switching from one to the other.That's odd that you would have trouble switching from one to the other.I talk to guys at work, has been tested but said there wasn't any real changes to sync set-up for 09.
I've had this happen to me too, a friend said that it maybe some thing to do with the satelite update there doing ?
If you remove the back cover of your seat you will find wiring for headrest.Trace the wires there should be an audio out cable.If you find it you can connect it to your line-in plug in center console.Thats how I connected my units.As for your picture check wire in same area to make sure the are linked together with video out to in on one of them.
Are copys ready yet ?
Are you selling the moniitor $50 each or the pair ? please PM I would like them.
