Dymes
About Dymes
Dymes's Achievements
  1. Remove the back scuff plate around the trunk latch by pulling up ur S/N will be on left side on silver box that the sat module.
  2. Sorry for the delay in responding. It took me about an hour to set up everything. Steps 1 Peel off the the tape from head light wires so they are is only the 2 wires about 12ins retape them back up as headlight wires only. 2 The wires should now reach the fog lights an plug them in !!! ( tape up passenger side original fog light wire nolonger need) 3 On the drivers side take original fog light plug an plug it in to relay harness (U only need one connection for harness) 4 Connect relay harness to to HID ballast left side an right side an connect bulbs in to headlights. 5 Relay harness needs to be grounded my harness had ground wire on left side an right side an then connect positive to the battery !! That's it really, now with switch in auto an pulled out your light will work as fog light runnig light during the day an at nite your HID will auto, come on !! will try an get some pic this weekend..
  3. I have HID head light in my edge I went a little different way with mine.I switched my headlight plug in with my fog lights so now I have silverstars bulbs in my fog light lens an come on as my running light DRL during the day.I leave my switch in auto spot with fog lights on so when it gets dark headlights come on automatically.So now during the day no headlight just fogs.HID work great no flickering still use relay harness.Neg.. to this App when you turn on high beam low beam turn off (like fogs would) but now your fog lights stay on now because they are the low beam..I have 8000k HID so I really never use high beam.... hope that makes sence !!!!!
  4. Dymes
    3.7L
    Mustang maybe MKX not likely heard they cann't fit the turbo set up in ? <_<
  5. At work they are calling it the 2010.5 we start building them in feb maybe.
  6. I also have seen the new edge an mkx .I heard that there will be a 2.5 ecoboost engine an regular 3.5.Mkx will also have a 3.7 offered no ecoboost
  7. I call Navteq said I can get a disc for a great price of only $249cdn told them to keep it
  8. A friend had problems with his lift gate took it to dealer an realized he was missing a rubber stopper on the lift gate causing uneven presure went it came down on.Not sure this applies to anyone
  9. Edge sport has black ones depending on front bumper you may not notice.
  10. I have the same problems sometimes I don't think theres a real fix for it <_<
  11. That center cap can be changed.
  12. Yes the head unit is now a Sony but like sync I think you need to download updates for it
  13. I'm use a 7p copy now an it works fine 8p will work on your edge don't let them tell you differently....
