jimbop99
Everything posted by jimbop99
Front defrost not working
jimbop99 replied to ivan1ramos's topic in Interior, A.C., Heat, Interior Trim
Try this: -
jimbop99 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
This wasn't all today but over the last couple weeks. Changed the headlight bulbs to the vosla +30 bulbs, replaced the front emblem, added a steering wheel cover and put on a rear bumper protector. -
Thanks. I'm using the Ford recommended orange coolant. Same stuff she came with. -
I've got 63,000 miles on her and I put on about 12,000 miles a year. What kind of interval do you recommend I use for the next three drain and fills? -
I decided I would do the radiator drain and fill with 63K on my 2014 with 3.5 V6. I put it up on ramps and drained the radiator. I was a little disappointed to only get a gallon of coolant out. I guess I'll just hold on to the second gallon of premixed and do it again in maybe 5,000 miles? -
I personally wouldn't bother with navigation. Nowadays your cell phone will do a better and cheaper job.
2007 Lincoln MKX ABS Font Sensor Rings Cracked
jimbop99 replied to drs120new's topic in Brakes, Chassis & Suspension
I had an Escape and both tone rings cracked and caused the ABS to kick on. I found someone on-line who cleaned up the rust and JB welded the ring back in place. I did this and it had held up for over two years and was still working when I sold the vehicle. I don't know if anyone has tried this with the Edge yet. As far as driving without the ABS enabled, sure you can drive it that way. I drove for years without it because it wasn't invented yet. The only issue is if your state has some form of safety inspection to renew your tags you probable wouldn't pass with the ABS light on. -
I was wondering how much coolant was required. Did you just drain the radiator and refill? -
This is what I put in. http://drivebright.com/home/shop/ford-edge-led/
She needs new brakes and I usually do them myself but it's been in the mid nineties, and according to the weather forecast, will stay this way for the foreseeable future. I don't have an air conditioned garage so I think I will just take it somewhere. Do you recommend a dealership or an independent shop with good recommendations?
Thanks. Somehow "Just items I follow" got checked. Senior moment. Thanks!
Anyone else having issue with "View New Content"? I always get "Sorry, no new content found" even though I can tell there's been posts since last time I visited. I tried signing out and then back in with no change. Thanks.
You could try plasti dip. http://www.fordedgeforum.com/topic/19700-plasti-dip-on-wheels/?hl=%2Bplasti+%2Bdip+%2Brims&do=findComment&comment=145666
I'll give it a shot. Sounds like a bad ball joint.
Exterior Key Pad - No code...
jimbop99 replied to nittanydoug's topic in Alarms, Keyless Entry, Locks & Remote Start
Would love to but I didn't bother taking pics. Sorry. They look good. -
Installed drivebright drl's. It went fairly well. The hardest part was routing all the wires and making sure they were well secured.
