Fishinfool98
About Fishinfool98
520 profile views
Fishinfool98's Achievements
  1. The #1 has no power! The plug has not been fired at all. No voltage shown at all on the coil
  2. 2012 Limited with 3.5 154,000 miles Engine developed a miss fire on #1 replaced plugs, coils and injectors. Still had misfire. sent out pcm. Get new pcm and replaced with another set of coils… still has misfire. Start ohm testing wires and find that I’m getting readings on multiple wires on each coil with all the coils and injectors disconnected, disconnect the engine to ignition harnesses and the issue goes away…. Test the ignition harnes and I have 5 wires that ohm test together. In desperate need of a wiring diagram! Any help greatly appreciated.
  3. Battery draining after loosing a coilpack Trying to find a constant hum is kicking my butt looking for a wiring diagram that shows what comes from the fuse that is 120amp on the battery
  4. Battery draining after loosing a country to find a constant hum looking for a wiring diagram that shows what comes from the fuse that is 120amp on the battery
