Everything posted by STB130
Sport mode keeps the trans one gear lower so at highway speeds your in 5 gear not 6! That could be most of your problem just leave it in Drive.
2016 Average since new 3034 miles 21.2 overall, one highway trip 25.7
Yes That why you have to find a good shop to bend the pipe
Here is a Exhaust system with free shipping from summit still needs shop work to bend pipe and install probably 2-4 hours labor depending if the have computerized bender for our chassis
Here are some SS mufflers from Magnaflow that are similar to the ones used in their cat back for the FWD Sport. The shorter one I would use in the back and is straight thru design the other is longer for under car and has an internal X-Pipe also striaght thru design. Of course you will need muffler shop to bend pipe to fit and weld hangers to fit stock locations. MRT mufflers hang too low while these will fit the stock locations. Amazon has mufflers for $93 and $123. Pipe, labor etc should be $300-400.
Both have nice long TQ lines. Does anyone know what the names of these tunes?
Maybe he was referring to the lowering springs http://www.vaccar.co/store/p103/Eibach%3A_Pro-Kit_Lowering_Springs_%28Fusion_2013_%29.html
Looks like it for Fusion so might bolt up to the edge chassis since we share the same platform as the Fusion https://www.airliftperformance.com/vehicle/ford-fusion-cd4/#fitment
From the album: Drag Cars
2016 Edge Sport -
2006 M&M Dragster 7.38@181 -
2002 Camaro Super Pro 9.56@138 -
1979 Hurst Olds K Stock Automatic 12.26@114 -
55 Chevy Belair Super Gas 9.18@141 -
Easy way to lower Sport is do change tires to lower profile and recalibrate speedometer with tuner device, eg 245/30ZR20 90W XL 182780 10.2 25.83 9.76 8.0-(8.5)-9.0 Nitto NT555 will lower Sport by 2 inches 29.8 vs 25.83.
Why would the MKX tune not be available for the Sport? They are on the same platform with the same body and mechanicals; trans, AWD, etc. only differences are front and rear trim and interior trim.
Walmart.com has oil filter for Sport shipped free to store where I buy the oil so its all in one trip MOTORCRAFT FL2062 FILTER-OIL $7.85
t Still seems too high if this dyno chart is correct? Also do you think the Lincoln tune is going to be a problem with trans? 426 # vs 350# on edge
Anyone have the new Unleashed tune?
