DaMiFo
About DaMiFo
2,568 profile views
DaMiFo's Achievements
Rare
Rare
Rare
Recent Badges
2013 3.7 Sport - CV Boot Replacement
DaMiFo replied to Miner's topic in Brakes, Chassis & Suspension
They don't want to replace just the boot because (as you said) it's a messy job and time consuming, when for not much more you get the complete axle shaft assembly already packed with grease and sealed up. If you're doing it yourself, want to save money, and don't mind the additional time & effort, go for the boot only. But if you are paying shop labor, having them assemble it and the "materials and cleanup" costs will most likely make up the cost difference since it's so small anyways. Also, the axle/hub nuts are one-time use and need to be replaced any time they are removed after being torqued down. This is normal for most, if not all manufacturers. -
Not sure if it's the same story with the Edge, but way back when I had my '10 Focus SES it did the same thing in park/neutral. I remember the shop manual for that car said it was also normal, and was to protect the exhaust & related emissions equipment from overheating due to lack of airflow when the vehicle is not moving.
Poor choice of words on my part. Maybe I should've used 'average' or 'most common'. But yes the actual use cases are listed in the manual like you said. My point was majority of places (yes, not all) will say 5k miles, and most DIY owners (at least from the forums I am on, myself included) do it every 5k miles as well.
Yup thanks for the correction - sorry I'm in the middle of a project on an older Ford and was thinking of the old method!
The reason you can't change the oil life monitor is because Ford considers it an "Intelligent Oil-Life Monitor". It's not a set time or mileage (well, the maximum of 10k miles or 1yr is), it varies depending on vehicle use. It's not an adjustable variable, it's part of the IPC firmware. The "standard" oil change interval for Ford (not "required" interval) is 5,000 miles. If you just go to any Ford dealer for an oil change, this is what most will print on the sticker, too. Will it hurt if you do 7,500 miles? No. But I always say if you care about your engine and/or plan on keeping your car, just go 5,000 miles between changes. It's cheap insurance.
Deactivate fake engine noise?
DaMiFo replied to Vanquished's topic in Interior, A.C., Heat, Interior Trim
If you think you have a blown speaker, I suggest you get the speaker fixed rather than disable the ANC system. The system has no extra speakers and uses the regular door speakers. Not true. There are actually several ways to "defeat it". You can de-pin the wires for it from the DSP, you can program it off with IDS (or FORScan of course), or in vehicles that have the full ANC system with noise cancellation, you can disconnect one or all of the microphones to create a fault in the system.- 6 replies
- blown speaker
- edge
The European Sport is not the same as the North American Sport. In Europe, the Sport was rebadged as the ST-Line (and both have/had 2.0 TDCI engines - and while there were two power options for the engine, there was no real engine upgrade like in NA).
The entire bracket/holder is gone. Are you referring to the radar module in the center of the lower grille?
While I'm on the "I hate front plates" bandwagon too, I would be pretty upset if I spent $40k on a new car and during delivery the salesman said "here's your front plate, you should hurry up and drill into your bumper to get that mounted" instead of just having it done. And since the majority of US states do require them, I understand why they're usually installed. There's far more people who want it done for them than those that don't, especially on an Edge. If it's that big of a deal, there's always the ability to order your own car and tell them to not touch it (with the exception of PDI safety checks) once it's delivered. That's exactly what I did with my Fusion.
There is no way to re-order the list of sources. That is programmed into the firmware and UI. You can only add or remove sources.
Do you have the adapter that fits to the factory wiring? You solder/splice the harness adapter and the radio adapter together, the connect that completed harness in between the radio & vehicle's OEM wiring. Wiring & guide (from Crutchfield - enter your vehicle to get the correct one): https://www.crutchfield.com/p_264MASTER/Crutchfield-Vehicle-specific-Instructions.html
Yes - I recommend checking out Crutchfield. They're a tad higher in cost (nothing crazy), but with the "accessories" (wiring adapters, etc.), instructions & diagrams, and phone/online support they more than make up for it.
https://www.nhtsa.gov/interpretations/9418
Rear fog lamps are not "illegal everywhere in the US". That's far from the truth. Besides, plenty of Audi, Mercedes, and Volvo vehicles are sold with them still equipped for decades. If they were illegal, they would be decontented from North American models. If legality is really what matters to OP in this post, you can easily look up your state's law. If you go with the aftermarket ones that are meant to connect to your tail lights, they often have a dim & bright level. You can usually connect either brightness depending on your use case, preference, or local laws if you intend to use them as rear fog lamps. Back to the initial post tho... You should be able to see which pin in the BCM is for the rear fog light through the North American version of the wiring manual directly through Ford. I did exactly what you want to do on my '17 Fusion Sport. Since the '16 Edge is so similar, I'd bet you'll have to do nearly the same thing as me. Connect one wire to the BCM connector, run it to the back of the car. Connect the lights to a ground in the rear of the car, pop in a European switch, and program the BCM and IPC with FORScan. EDIT: This may be of some help. Overall process is similar, and instead of connecting European tail lights, the new wire goes to the separate lights. Again, not sure if the Edge is similar or not so check wiring diagrams first: http://www.2gfusions.net/showthread.php?tid=8347 End result for me:
That's not how traction control works... It's only active if it detects slipping. Same with stability control - it's only active when it detects the vehicle out of control or sliding. As Perblue said, if your MPG's are different in any way, it's a different factor in play here. Personally, I don't see a reason why traction or stability control should be turned off 99% of the time, especially during normal driving in a car like the Edge. It's a "just in case" system - it's almost always inactive, but in the off-chance you have to swerve at 50MPH, that's the only thing between either the rear end slipping out and you rolling the car, or the car applying one rear brake for 0.2 seconds so it straightens out the rear end and you can keep going on your way.
