LEAKPRO
Everything posted by LEAKPRO
  1. MOPARTRUCK...Not all 2015's had the issue. What is the build date and serial #. The repair works. My company has repaired 1,000's of them. The carpets are dry after raining, is there a wet moldy smell, do you hear sloshing when driving slowly and hitting the brakes. If the answer is NO to those questions you will not have an issue. You are going to have to change your name to FOMOCOGUY now!
  2. the water, under padding etc...anything that I can maybe see as a possible culprit for your leak.
  3. This is a strange one. After a rain, can you look into the holes in the kick panel to see if there is any water sitting in the kick panel? The plastic trim will have to be removed. What color is your car...If it is a light color you can look for dirt or trailer marks. Can you take some pics fro me? I might be able to better see what you are seeing.....John
  4. If it was a clogged A/C Drain it would not be wet up the bulkhead/firewall. I suspect an aftermarket windshield. Is the windshield factory? If it was the roof pillar, removing the interior trim will show a wet stain or path and it is very easy to see the leak. No issues on previous years that are common. We have had water building up in the kick panels and filling the kick panels up and seeping in. email me john@leakpro.com
  5. There are no moon roof drain tubes on your car. Windshield or clogged A/C Drain is the likely culprit.
