mr_jason
Everything posted by mr_jason
I used airlift 60910 kit. Seems to fit and work well. Just got back from a cross country road trip with the edge packed and a tray hitch bike rack. Installed the bags between the coils with it lifted so suspension was extended.
I just added some aiflift 1000 ones on my 16 edge. They didn't have an out-of-the-box kit so I had to take my best guess on the sizing and part number. I'll see if I can find the part number and take a few pics. I haven't towed anything but I do load up the car and have a platform style hitch bike rack. So far so good. https://www.airliftcompany.com/products/air-springs/air-lift-1000/
Adding OEM hitch 2016 Ford Edge Sport
mr_jason replied to mr_jason's topic in Cargo, Hauling, Roof Racks & Towing
I think the hitch part number I ordered was ft4z-19d520-aa -
Mine came with all the bolts and instructions and torque specs. I also had to modify and fab up different sensors for the foot activated liftgate. The existing one on the bumper cover will not work since they go all the way across. -
It's on the outside. I use it for a bike rack most of the time so the lock on the pin is tight. It fit's, but tight. -
Hitch cargo recommendations
mr_jason replied to sreeve29's topic in Cargo, Hauling, Roof Racks & Towing
You can install a roof rack with the vista roof, I have one for my 2016 edge to carry a roof top box. Check the fit guide on yakima.com or thule.com they will tell you what components are needed for an MKX - if it fits and cost. It's going to be more than a hitch install. You could get the hitch and rent a small trailer to tow. -
Premature ball joint failure on Gen 2 Edge
mr_jason replied to Wesley's topic in Brakes, Chassis & Suspension
Mine is similar. It's not horrible but I get a popping noise sometimes when reversing from the front driver side and it wanders with imperfections the road. Haven't noticed any play the last time I rotated the wheels. I'll have to check again. I have a 16 edge sport. -
Forscan to enable tow lights
What's odd is the brown/red wire is connected at the fuse connector and then disappears before it passes through the firewall. -
Nice! -
Thanks for the update. Post anything you find out -
Had the same pricing issue, looked good until the shipping cost. Ended up just ordering it from a local dealer. Did you install it yet? I'm still waiting for the harness to the tow module 4 pin wire = F2GZ-13A576-A wiring to tow module which is on backorder = F2GZ-13A576-B -
I found the module on ebay. 4-pin wire on http://parts.ford.com . I still haven't installed the module though. The wiring harness for the car already had the connector just behind the bumper cover on the passenger side . You can probably see it if you remove the small plastic under panel. -
From what I can tell the UK version has a 2 tonnes = 4000kg = 4409lbs rating. The hitch itself is only rated for 3500-4500lbs depending on which one you get so you would be stretching it 187% more than what it was rated for. Even then tongue weight for that trailer looks like it's 800+ lbs. I would not tow it.
I don't recall the part number. I found it on parts.ford.com -
Did the same to my 2016 edge sport. I used the split kick sensors from a titanium edge, had to modify the lower slightly. Works great. Looks factory.
I had a notification on the ford app for 19B04 . Called, they order the part. Took it in an they had it swapped in about 1.5 hours.
Anyone notice any consistency when the warning light comes on? I've had the steering wheel go off center - took it in. Dealer said I must have hit something even though it drove perfectly straight and did an alignment. Few months later adaptive warning light came on but went away after turning off the car. Took it to dealer they didn't find any codes but I did have a picture of the warning light. They couldn't do anything without a code.
Thanks. I figured the module wasn't installed and could be - found a few on ebay. Was hoping I could plug in the module and it would work without having to enable in forscan. -
Anyone use forscan to enable the oem 4-pin trail lights? Or do you have forscan and can see if the tow module shows enable/disable like it does on the f150? I have 2016 edge sport which does not have the oem tow package but I added a hitch and an oem 4-pin. I did find the wiring harness actually has a spot to plug in the 4-pin wire and the tow fuse exists. I'm guessing the toe module/feature is turned off. Does the tow module show in forscan?
Hitch Receiver for Edge Sport models.
mr_jason replied to SLB1904's topic in Cargo, Hauling, Roof Racks & Towing
I can't recall the part numbers, the dealer looked them up for me. The lower mount was flat vs rounded so I had to fab up a flat mount to attach. here's a few pictures If you decide to do this or try to do this to your vehicle I'm not responsible for anything you mess up, break, destroy. You assume all responsibility. -
I added the oem hitch to my 16 sport. It's not designed to fit but I cut the hole for the receiver in the bumper cover to make it work. Also had to order the 'split' lift gate sensors from a titanium with the hitch to make foot liftgate work. -
I made the foot sensor work by purchasing the 'split' ones used on a titanium with the factory hitch. I have a sport so I had to cut a hole in the bumper cover for the hitch too and fab up the lower foot sensor mount.
