1004ron
    121
Everything posted by 1004ron
  1. How's the ST going, and have you decided the "next steps"?
  2. As far as I know its to do with the fact that the passenger side vent pipe ties into the intake downstream of the throttle body, so it sees vacuum at closed or very low throttle position, drawing the crankcase vapours in.
  3. Looks like its only available for Sync2 I'm keen to get map updates for my nearly two year old 2017 Sport - my home and a few of the new roads in my city aren't on the existing maps.
  4. Find the most reputable paintless dent repair place in your area. I had some inconsiderate bastard open his door onto my 2017 Sport when it was only a few weeks old.
  5. 1004ron
    Delivered!
    They were original install on my wife's 2015 Mustang, and we installed another set at 51K miles because they served us well and were well priced with a $50 rebate. Could have got another 2 to 3K miles out of them but wanted good tread depth for the winter.
  6. Just got back from the Ford collision centre where I waited just short of an hour for them to install the new light. Park Lamp - Ford (FT4Z-13200-H) $296.72
  7. 1004ron
    IDS/Scan tool?
    BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices That's not going to work with the Foscam full Windows version which is the only version capable of writing changes.
  8. 1004ron
    IDS/Scan tool?
    I bought the same one on Amazon and it works with my wife's Mustang and my Edge.
  9. Thanks for the feedback, and based on that I'll not bother with switchbacks for my front turn signals.
  10. It looks like the 7440 switchbacks have a separate wire to power the white LED's while the turn signals are not on - I'm not too keen on that arrangement, and not sure that it will actually work on the Edge due to the low voltage/intensity when the turn signal is not on. http://store.ijdmtoy.com/No-Hyper-Flash-7440-LED-Light-Bulbs-p/20-101.htm http://store.ijdmtoy.com/Single-Filament-7440-LED-Switchback-Installation-a/597.htm
  11. 1004ron
    20170823 170811
    I just cant find the thread in which you posted this - damn new forum software - I'm looking for the switchbacks
  12. I just installed the below eBay switchbacks in my wife's 2015 Mustang, and wondering if they are the correct ones for my 2017 Sport - can anyone confirm this for me? https://www.ebay.com/itm/7444-7443-Switchback-LED-Bulbs-WHITE-AMBER-Dual-Color-Turn-Signal-Lamp-Light/192443860151?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  13. Hopefully this light bar you plan on installing is legal - there's a couple of vehicles on my morning commute that blind all oncoming drivers with their light bars.
  14. Yes, snow and slush build-up does kick it off Cruise Control. The Adaptive Cruise and lane guidance works in most weather condition, day or night, but not snow.
  15. My wife's 2015 Mustang is that colour - one of my favourites "blues".
  16. That doesn't sound like a noisy lifter - I'd get it to the dealership service center ASAP and have it addressed under warranty. I have the same model, it it does not make any noise - you could add your model/engine to your profile.
  17. No such video comes up in a search - what's the title? Any chance of responding to the questions previously posted?
  18. Unlikely that its normal. What engine? What's the mileage? What's the service history, when last was the oil and oil filter changed? What oil and oil filter have you been using? If not OEM oil filter it might not have an anti-runback valve. Any sign of sludge when viewing into the oil fill cap? It could be an oil pressure problem causing the valve lifters to make a noise.
  19. I'm not sure which item/component you're referring to. Bear in mind that I didn't check for error codes seeing as I knew exactly what the cause was - check @WWWPerfA_ZN0W for the likely cause of your error code.
  20. Here's a photo - I'll try find a better one. It gets in the way of the fill plug, so I unplug it when filling. The brass device is the temp sensor.
  21. When I turned on the ignition after I did a lube service, which included the PTU, I got this warning light, .......... because I forgot to connect the PTU temperature sensor.
