1004ron
    141
Everything posted by 1004ron
  1. If you believed Ford's claim that the PTU was "lubricated for Life", and have 78K miles on it, then not too unexpected.
  2. Congrats and welcome - I like that colour. The firmness of the suspension is subjective, but I don't feel mine is too firm, and expect the 2015 and 2017 would be the same.
  3. I do as well, and I find the dashboard pressure indication to be accurate and check it at least once a week and if it drops one or two psi, I top it up with my home compressor using an inflater with an accurate gauge.
  4. Keen to hear if you get more out using the oil extractor through the dipstick vs the drain plug. Most folks use a lot more than 5 quarts to change over a higher percentage of the total volume.
  5. When last was the cabin air filter changed, and do you continuously use recirc?
  6. One on my Edge Sport and one on my wife's Mustang
  7. We're all welcome to express our personal opinions here, but I'm interested to hear your reasoning behind that comment.
  8. Looks aside, myself and others here can confirm that the JLT performs well, which would make it a whole lot better bang for the buck. The two JLT that I have were bought when they had a seasonal special, so think I paid around $135.
  9. @bb56 I can envisage those washers working, and I have some of that foam you described and will give that I try.
  10. Service manager just replied to my email with a copy of the TSB and the below comment - I've replied asking if mine is covered under the ESP. Edit: His reply: Not much is covered under the ESP , extended warranty. Might try the new type fasteners, if my string work-around gets loose.
  11. My comment is based on how tricky it was to get that Retainer Ring fully seated with the shield off the car - as you say, it may have seated and you'll know some time down the road, but then again I used the same kit on mine and its vibrating again.
  12. What M/Y ? - is yours still under warranty? Good idea to add that to your account profile. Mine came and went for about 10 days, and haven't seen it again since.
  13. Thanks. Will send a query to my local service manager for warranty cover. Not sure if the below confirms that mine is still covered by the ESP. https://ford.oemdtc.com/3633/underbody-shield-rattle-noise-while-moving-2015-2017-ford-lincoln
  14. OK, looks like item 2 and 4 which is a red plastic anchor with a metal self tapping screw. I can see this being an improvement. Amazon has clearer images of this, and would have to measure the diameter of the large hole in the body metal to see if it can lock in. https://www.amazon.com/Engine-Undertray-Cover-Bottom-Shield/dp/B07B26FNBZ/ref=pd_sbs_263_5/138-3585131-1943450?_encoding=UTF8&pd_rd_i=B07B26FNBZ&pd_rd_r=124286bf-8c92-4054-8be0-2b94153abfcc&pd_rd_w=XiF6X&pd_rd_wg=xirYl&pf_rd_p=7cd8f929-4345-4bf2-a554-7d7588b3dd5f&pf_rd_r=Y4J9M9BMSAGJKDWQ0SN0&psc=1&refRID=Y4J9M9BMSAGJKDWQ0SN0
  15. I'm having difficulty finding the revised part you mentioned - I'd like to compare it to what I installed. I'm at three years and 54K miles - wonder if the extended warranty that I paid $1.9K for will cover this?
  16. Watched you video - my personal opinion is that the flutter will return pretty early using this method. On yours the ring is not locked onto the clip that has the foam washer keeping some compression on it, and this can only be done with it completely removed from the vehicle. The image attached shows the step that is virtually impossible to accomplish without removing the shield from the vehicle.
  17. The only Motorcraft fluid I've used is the transmission Mercon LV I believe my choice of Engine, PTU and RDU fluids are superior to Motorcraft. Changing the transmission filter on these means removal and splitting of the trans, so agree, don't consider that as required maintenance.
  18. Welcome !!!! My 2017 Sport's wheel gets comfortable in 30 seconds and cosy at 1 min. Never had the need to use gloves. Make arrangements to meet the service manager first thing in the morning and do a comparative test with similar vehicles in their lot - one of the cheap IR temp guns and a stop watch would be handy.
  19. Must have a large balcony for the Edge to park on it. Where was the food and how did it get contaminated?
  20. The PTU holds almost a quart. Why don't you consider the post directly above yours - a drain plug?
  21. 7 Months and 9K mile update. When braking at speeds 40 mph and below there's a faint growl and light vibration which changes as the speed peels off and it comes to a stop - not bad enough to make me want to rush out and buy new brakes. The original rotors were definitely warped based on the lower frequency vibration when braking at speeds 60+ mph, but were smooth at lower speed. My wife's 2015 Mustang with the original solid rotors is smooth at all times, so might go back to solid rotors next time. Edit: Sent an information request to Power Stop and within a day they responded by email and called, offering a new replacement kit.
  22. I did a search on my past orders from Amazon and all my purchases were found in the below list, except for the Mercon LV, but that was also from a reputable seller. Some air and oil filters bought on Amazon were from Greenway Ford. I'll be paying close attention to the seller when buying on Amazon.
  23. Old thread, but another thread prompted me to check my spare and it was at 21 psi. My manual sates:
  24. Checked for the first time in 3 years and found at 21 psi.
