Everything posted by 1004ron
Great, and the first picture shows the port for "Sensor 2" downstream sensor that the OP is looking to confirm.
I see it, but can't tell if its after the first CAT - the Front/1st O2 sensor is immediately after the exhaust manifold, and these days the 1st CAT is also very close to the exhaust manifold.
I trust that you no longer seek advice from him. I recall that there was improvements made on the later models, where the pump leak path is outside the engine - maybe others more familiar with this model can confirm.
It is the one after the first catalytic converter - cant tell clearly from your photo.
Why is this site servers so unreliable ?
1004ron replied to 1004ron's topic in Forum Help & Site Suggestions
You're welcome, although history suggests that its not too obvious. -
If I was paying for it, I'd be having a serious discussion with service provider, making it clear that I'd be looking at alternate providers. -
Out of the 4 auto forums I frequent, this one is the most unreliable - so often down and no notice that its under maintenance etc.
Rotors & Pads..Power Stop, Stoptech or EBC?
1004ron replied to ThugFordEdge3.5's topic in Brakes, Chassis & Suspension
I don't use a torque wrench on my wheel lugs, and I don't believe the lug torque could cause the rotor warp - Mine warped at around 35K miles. I installed the Z23 brake rotor and pad kit seen in the below thread - $169 on Amazon, seller was Jeggs - shipped directly from the maker in 2 days - got about 4K miles on them now and they're great - no vibration when breaking at high speed, and good grip. -
1004ron replied to ben senise's topic in Accessories & Modifications
Gear # indication. A while back I drove a rental Expedition and it showed gear position all the time - is there a way to do the same on the Edge? If you use the paddles it will briefly display the gear # that its just shifted to - is there an option to have it display gear # at all times? -
The bold part - isn't it the opposite? Would have been great if you could replace the filter on this model.
SYNC3 Map Updates Available On Line
1004ron replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Just a few months after purchasing my 2017 Sport new, I got a Sync3 update free, and a couple more free Sync3 updates over the past couple of years - using your reasoning, shouldn't they have charged for that? At the time of purchase the maps were around three years old - yes I can get by with them, but its not unreasonable to expect more frequent map updates (free or paid). -
I've had my Sport for 2.5 years but never set up this keypad, mainly because I didn't think I'd ever use it, but this thread perked my interest. When do you guys use this keypad?
It could be a number of things, parasitic draw, battery failing prematurely, ...... With it being new , my suggestion would be to have the dealership do a parasitic draw test and a battery load test. You could also get the battery load test done at free at places like Autzone, and at least you'll know before heading to the dealership.
Last week I was downtown and the new NA 1 18 map had the extensive road works and flyovers covered, in addition to my home address - pleased with the update, but disappointed that my 2017 that shipped with way out of date maps, and this update wasn't free like the 2018 and 2019 models. -
Cleaning wax off black plastic parts
1004ron replied to 1004ron's topic in Appearance - Detailing, Wash & Wax
Be very careful with those, the "Magic" in them is abrasive and will damage textured and gloss finishes. The Warning Label Melamine foam erasers work well; but on surfaces that are painted, polished or easily scratched, they might work a little too well. It's recommended to test the eraser on a small, preferably unnoticeable, portion of whatever you're looking to clean before you dive on in. https://www.wired.com/2015/09/whats-inside-mr-clean-magic-eraser/ -
I've read that and tried it, and can confirm that it "works", but for a very short time - the oil just masks it for a little while. I've found a small firm brush with detergent or mineral spirits to be the most effective long term solution, followed up with frequent use of 303 UV Protectant -
Not sure if you tried the search function? https://www.google.com/search?q=https%3A%2F%2Fwww.fordedgeforum.com+water+pump+internal+leak&rlz=1C1GGRV_enUS769US770&oq=https%3A%2F%2Fwww.fordedgeforum.com+water+pump+internal+leak&aqs=chrome..69i57j69i58.12382j0j8&sourceid=chrome&ie=UTF-8&safe=active&ssui=on
I'd recommend the same. I did multiple drain and fill just last week at 46K miles, and each drain was a fraction over 4 quarts. I used almost 12 - 13 quarts - last quart was used to top off and get level exact.
Best price, and even better when on sale like Memorial Day, fast order processing and delivery. I recommend them.
Thanks @omar302 I'll just install the new tires and take a chance with the existing TPMS sensors and valve stems. I've still got to find a local installer for the Aturro AZ850's that I bought a while back when they were on special with Simple Tire.
That's my experience with my 2017 Sport. I have another question, I'll be replacing my tires soon at 50K miles and 2 years 9 months - should I replace the sensors at that time, or at the next tire replacement around 100K miles 5.5 years? Google suggests the sensors are good for 5 to 10 years.
I think non-interference engines are very scarce these days, .......... maybe a Tesla ?
That looks like it's road debris stone chip, which mine has a few. I frequently inspect and touch those up.
Thanks for the update.
