Everything posted by 1004ron
Loud clicking when turning right at slow speeds
1004ron replied to fishx65's topic in Brakes, Chassis & Suspension
If you pull off with the steering full lock and it clicks, that's a sign the CV joint is gone - they should last well beyond 100K miles unless the rubber boots have been damaged. Check the the drive shafts for signs of lubricant leakage from the boots. -
I used Redline 80W-90 in the RDU Why would you change the oil weight?
Reading the thread title the first thing that comes to mind is CV joint, but just for clarity, does this only happen as the steering is rotating, or does it happen when pulling off with the steering at full lock? -
I paid Tire Discounters $138 for the installation, balancing and disposal of the old tires. Free wheel alignment check was included - they got it up on the Hunter rig and came to me with the printout showing rear and front toe out by a small fraction (three decimal places) and recommended that I pay the $90 to have it corrected - they weren't impressed when I said no thanks - my tire wear has been perfect and I see no reason to disturb that for 0.002 toe. I've only got 550 miles and happy with the Atturo so far - quiet and good in the wet - I'm not a "spirited" driver, so can't really comment on grip etc.
What pads and rotors do you plan on using?
We're all entitled to our own opinions, right or wrong. I've become familiar with the OP @snmjim on this forum, enough to establish the opinion that he's a suitably qualified and experienced auto enthusiast for me to trust his product opinion and review. This was confirmed by myself when installing the product and after 3 months in service. Come now, you can't hide behind the fear of law suits - you know that there's no way that you're at risk of that on this forum - maybe @akirby and put you at ease, and allow you to explain what you consider bad about this product. What brake kits do you consider better than the Powerstop and cost less?
Very minor irritation - every time I go through the car wash water hangs out in the side mirrors and spits down the side of the vehicle when driving and dribbles down the door when stopped leaving ugly water marks. I reduce the volume of water by pulling to the side at the car wash and using a can of compressed air blast into the mirror. I'm thinking of popping out the puddle lights and checking if I can drill a reasonable drain hole in the underside.
I like the ST, but not enough to trade my Sport on it.
Can Forscan enable showing the active gear?
1004ron replied to Jombi's topic in Accessories & Modifications
Question asked here - near bottom of page: -
Fluttering Noise from Undercarriage and Dashboad Rattle
1004ron replied to CCMAYES72's topic in Brakes, Chassis & Suspension
The rattling undercarriage has returned, so I'll just look at doing the string wrap again, and repeat it as needed in the future.- 90 replies
- dash noise
- dash rattle
(and 4 more)
SP-542 are hard to find now - although I've got another 50K miles before I change plugs, I'll go with the NGK 95605 Ruthenium HX, unless I can find a good reason why Ford changed to the SP-578
The sensors inside the tires have batteries installed and send a wireless signal to a receiver on the car at set intervals - they remain active when the wheels are off the vehicle. To conserve batteries they only transmit when the wheels rotate.
Don't the wheels need to rotate for the sensors to transmit? Edit: I see your comment that they should be "sleeping" if not rotating.
What type of Performance Parts, that aren't shared with the Sport, did you have in mind?
I pulled one of the front spark plugs and it is in pristine condition and still at the design gap - definitely still good for another 50K miles.
Anyone gone from the SP-542 to the SP-578 which Ford now list for our 2.7's ? https://shoforum.com/index.php?threads/spark-plugs-sp578-new-part-number-for-542.139471/ Or is there a better option such as the NGK 95605 which is listed for this engine on RockAuto.com - https://www.rockauto.com/en/moreinfo.php?pk=9779988&cc=3310415&jsn=1829
Thanks @omar302 , I commented in that thread just recently and didn't think to connect it to the symptoms - I'll definitely check that out. I'll use Forscan, and if the error code is present I'll get it addressed under warranty - I've only got 50K miles on the clock, and paid just shy of $2K for the extended warranty, so as much as I like tinkering, I'll leave it to Ford.
Today, shortly after filling up at Costco, while idling waiting at a light it stumbles/misfired very lightly, and at first I thought it was the female driver on her phone that touched my bumper, but then noticed the tacho also show the irregular beat. No Check Engine light, but will connect Forscan and read the codes this weekend. I'm at 50K miles and planned to do an oil change within a week or two, and will replace the spark plugs with originals. Could someone let me know everything I should order for this job, like intake gasket etc.
I'm in Louisville KY. I have a new set of Aturro tires in my garage that will get installed in a month or two, .......so if I can get these for a good price I'll store them for the next tire change in about two years from now. I'd prefer that you set a price, and of course @TrueBluFam asked first.
