Everything posted by 1004ron
1004ron posted a gallery image in Member Photo Albums
I use four jack stands on my level garage floor - I've also done it on four ramps which is quicker and easier - I don't remove any wheels, but the ST might be different and require a wheel removal.
Group 65 Battery in 2nd Gen Possible?
1004ron replied to omar302's topic in 2015+ Edge & MKX Generation II
All the more reason to test it. -
It does not have to be fully charged for the type of tester that I posted - my tester has been very reliable. -
Why not get the battery tested, or buy one of these testers (I have this one): https://www.amazon.com/gp/product/B07Z67MMGC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 -
onyxbfly has the H7 installed, so ask him for photos of the installation and that will give you a good idea of the available space to accommodate the H8. -
Transmission loses track of its gear
1004ron replied to calling_john_galt's topic in 2015 Edge & MKX
Welcome. What's the mileage and service history? Have you done any maintenance on the transmission, such as a fluid replacement? Did you take it to Ford for them to diagnose it and quote on repairs if needed? -
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
1004ron replied to shumax's topic in 2017-2018 Edge & MKX
Thanks enigma-2 As you can tell, I didn't Google it before posting !!! I'll do that test, which is easy enough, but I'm starting to suspect that the issue is elsewhere, possibly the canister. A few thoughts - pull the electrical plug on the EVAP valve and run it like that for a while, even though that may generate a code, or leave the hose from the canister off and wrap some fabric around the inlet to the valve as a filter to prevent ingesting dust/debris. -
Replaced rear driver side tire today. 2018 Titanium
1004ron replied to flymore's topic in All Wheel Drive (AWD)
The 2019 onward, do they still have the coupler in front of the RDU in addition to the one in the PTU? -
Correct, no codes. Air filter is clean - changed only 4K miles back. Spark plugs and PCV valve changed 2K miles back. I'd not suspect any of those considering idle stumble occurs only immediately after gassing up at idle, and then nothing until the next time I gas up. Exact same symptoms which cleared with a new EVAP valve - just wish I knew the procedure to test the valve, but now leaning towards spending the $70 for a new OEM replacement. -
The rear drive does disengage on my 2017 Sport and I'd be very surprised if it's changed on the later models. Please add your Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ -
36K miles and three years after replacing the EVAP valve its stumbling at idle immediately after gassing up, and NO I don't click the nozzle again after it shuts off. No codes this time and I removed the valve and without power its shut and holds vacuum. Might buy just the valve and attempt to install it on the original assembly. -
For any difference in wheel diameter/circumference between the left/right wheels on any differential front/rear will have that differential working harder for every mile covered, and the size of that difference will determine how many miles before failure. Tire rotation is important, but has nothing to do with the impact on the differential due to diameter/circumference. The left/right imbalance might be more detrimental on the front as the front wheels are always powered, whereas the rear disengage at cruising speeds. Some tire places will trim a new tire to match the existing three. -
2016 Edge Sport Alternator Job - Anyone have details?
1004ron replied to Cerberus's topic in 2016 Edge & MKX
Why not go to a site like RockAuto.com and select the parts listed for your model? Sound like the Fusion guy is leading to more confusion. What Model & Year Ford Edge do you have? - please add that to your profile signature - https://www.fordedgeforum.com/settings/signature/ I highly doubt that the AC compressor needs to be removed for an alternator replacement. -
Attention - there's an uptick in accounts being hacked
1004ron replied to 1004ron's topic in Forum Help & Site Suggestions
paradiddle1 Been a member since 2014 and his account was hacked by Russian POS today -
Burning 1qt in 1200 miles is unlikely going to be seen in the exhaust plume. Need to track down the oil consumption path, possibly a bad PCV valve etc., or worst case piston rings.
Brake Pedal continues to go to the floor
1004ron replied to Blingamaring88's topic in Brakes, Chassis & Suspension
Welcome. If the bleed process is correct then I'd suspect that you got a bad replacement master cylinder. -
2016 Edge requires new wheel hub to replace broken stud?
1004ron replied to Raycaster's topic in Brakes, Chassis & Suspension
Curious, how did you break it? - need a torque wrench? Sure the 2016 is the same - maybe @Haz can confirm FRONT SUSPENSION. BRAKE COMPONENTS.. 2016 Ford Edge 2.0L EcoBoost A/T AWD SEL Sport Utility | Lakeland Ford Online Parts, Lakeland FL -
That's called a "speed nut" and @Haz could help with the Ford part number. It actually threads on, not push-on. Many places stock this type of thing. TIFCO Industries - Auto / Body Shop, Speed Nuts, Metal Screw, Flat Ford Lincoln Mercury 1/4"-20 Thread Pal Speed Nuts Dash Trunk Firewall 10pcs LB | eBay Ford 3/16" Stud Dash Trim Molding Clip Emblem Pal Thread Cutting Speed Nuts 10 Q | eBay
What are you using to read codes?
