1004ron
    109
Everything posted by 1004ron
  1. Bad interpretation on your part with regards the light - coming on and off while the engine is running means that the pressure was switching from above and below the minimum pressure required for the engine to operate safely. The light should always be assumed to be legit until such time it has been proven otherwise with a pressure gauge. The light on for a minute or two is enough to do damage and a couple more to destroy the engine. My guess is that your wife will agree to listen when she sees the repair bill.
  2. The light that came on is a low oil pressure indication and that means STOP - it's not an oil level indicator - take a look at the owners manual. Although the owners manual covers this, I believe it should be a little more persuasive. If the engine was shut off immediately the first time the low oil pressure light cam on, you would not be facing the cost of a new engine.
  3. Pretty obvious it is related. A low pressure indication light should always be assumed to be legit until such time it has been proven otherwise with a pressure gauge, or a new switch. If a low pressure oil light comes on, the driver should be taught that means immediate engine turn off. My thoughts are that you need a new engine.
  4. Welcome. If they did what you say, then you're right in expecting that the threads are damaged.
  5. I cant help with the torque values as I don't use one for this job. In the last picture you'll see the Loctite thread lock stick. I use a jack with a weld/bead/seam protector in the location seen in the attached photo and then position the jack stands, also with protectors, on the locations marked on the beads as the standard jacking points. The position that I have the floor jack lifts the front and rear evenly - center of gravity.
  6. Welcome. A combination of Caps Lock and the lack of punctuation, neither being against the rules, makes for a very difficult read and quite possibly many experienced auto enthusiast members might not be able to decipher it, which may result in your post not receiving any valuable responses. It might be in your best interest to give it another try.
  7. Just an additional tip, first remove the fill, then the drain - I found these plugs very tight, and you don't want drain and then have difficulty pulling the fill plug - yes, there's been reports of that.
  8. 2012 Ford Focus I know Sync3 is probably the same, but wouldn't it be best to ask on a Ford Focus forum vs this Edge forum? https://www.allfordfocus.com/ https://www.fordforumsonline.com/forums/ford-focus.15/
  9. If the first picture is "after" then you sure nailed it without going too dark - looks good.
  10. I've seen them for the G2 Edge but nothing for the G1, and Google comes up with nothing.
  11. Same part number of the set I bought except the suffix is AA vs mine are BA Any chance of someone with a steady hand taking a photo showing how the form follows the contour of the trim? FT4Z-16A550-AA https://www.amazon.com/Ford-Genuine-FT4Z-16A550-AA-Splash-Guard/dp/B010X49B1Q
  12. Some folks, especially those paying a service shop, consider it cost effective to change the coils at the 100K mile with the spark plug change, due to the high labor cost to get to the rear three. Seeing as the labor cost doesn't impact me, I do not plan on changing the coils until they show signs of failure.
  13. I pulled a plug to check how they were doing at 50K miles and confirmed that they'll make the 100K miles with ease. When I get to 100K miles all I'll be changing is the plugs, not coils, and considering the new NGK 95605 Ruthenium HX No experience with TSP products, sorry. Why do you plan on replacing the coils? https://www.rockauto.com/en/catalog/ford,2011,edge,3.5l+v6,1446671,ignition,ignition+coil,7060
  14. I think you'll need to turn on the flash and take another photo.
  15. How dark did you go with it? I've seen a good few in my town that are stupid dark and present a safety hazard - it's illegal in my state, but so is texting and driving, and neither is policed.
  16. I still listen to the same music I did when in high school, Classic Rock.
  17. I've always had my A/C in Auto mode and close to three years old I got it for the first time - it came and went for about ten days and haven't seen it since.
  18. 1004ron
    Hello
    Welcome and congrats. Looks like a few of us here have similar tastes. 17 Sport 08 H-D Nightrain 15 Mustang V6
  19. As far as I know the only method available is Foscan.
  20. Might be best to encourage folks to put it in their signature line if it keeps disappearing from below the avatar. Edit: I's still showing in mine.
  21. I added that to show a friend that I got "paid up front", .......by myself. LOL Damn good beer. The rotor laying on the floor is the 8 month old 9K mile Power Stop that started making a growling noise and slight vibration at low speeds - they promptly sent a complete new kit, but will go with solid rotors next time.
  22. I think I did the transmission drain with it on ramps. Just this past weekend I had it up on stands to rotate tires and replace the front brakes - the position of the floor jack lifts it level.
  23. Yeah, it should be be able to go 78K miles on the original fill, but most here that do their own maintenance change it around half that mileage. I'm keen to see photos of yours to see if it destroyed itself or possible an external impact - there's a few reports of them grenading.
