Everything posted by 1004ron
A "5 week old" vehicle with a poor maintenance record for its 135,000 miles covered?
My wife's 2015 3.7L V6 water pump started leaking at 63K miles and a little research uncovered a TSB covering the premature pump failure and the cure being a check valve in a hose that runs from the expansion tank to the thermostat housing. The TSB covers models up to 2014 and my wife's being a 2015 should have had the check valve installed in the factory, but it didn't have it - my dealership contacted Ford Corp and they agreed to implement the TSB. Could it be that this check valve plays a role in the pump failures on the 3.5 and 3.7L Edge? https://ford.oemdtc.com/588/coolant-pump-leakage-2011-2014-ford-mustang TSB 14-0212 ISSUE: Some 2011-2014 Mustang vehicles equipped with a 3.7L engine may exhibit coolant pump leakage due to air entering the system.
anyone here use an impact driver when changing wheels?
1004ron replied to ben senise's topic in Wheels & Tires
My dealership used an impact wrench on my 2017 Sport for its first couple of tire rotations, and chipped the coating on my wheels and damaged the two-part lug nuts. Ford replaced the lug nuts and I do all tire rotations without using my impact wrench on them. -
Hi, I'm Cori from the Alberta, Canada Rockies
1004ron replied to Cori Young's topic in Welcome Forum!
Welcome. Please consider adding location and Model/Year to your signature - https://www.fordedgeforum.com/settings/signature/ -
Taillight Condensation In Ford Edge
1004ron replied to Debbie Golden's topic in 2015+ Edge & MKX Generation II
Welcome. Try a forum search and you'll find a number of threads on that topic, and a few that will answer that question in detail. Please consider adding location and Model/Year to your signature - https://www.fordedgeforum.com/settings/?area=signature -
LOL, that's way off-topic.
I run the $17 Ford Motorcraft and real happy with it. Its highly unlikely that the engine can ingest/swallow the volume of air that the stock air filter's flow restriction inhibits performance.
Seems an awful lot just for the sound.
I bought my Sport new in March 2017 and by the time they released the new map version mine did not qualify for a free update, even though the maps were about 5 years out of date at the time I bought - I just paid and got the new version. Please consider adding your location and Model/Year to your profile signature - https://www.fordedgeforum.com/settings/?area=signature
2015 titanium power lift gate release latch?
1004ron replied to 2011edgese's topic in 2015 Edge & MKX
What about @Perblue 's post? -
Sorry that your thread hasn't drawn many comments, but keep it to just one thread, this one. -
Welcome and congrats on your new ride.
Recently I can only have the acc power on for 5 max 10 minutes before I get the warning that the battery is running low, and in response to that warning I start it and when it starts all the dash values such as remaining miles on tank etc. are reset, indicating that the battery is nearing end of life. This is my daily commute, so don't encounter any issues, only on the odd occasion when I use it on acc power to access the setting or dial in a GPS address. Bought the vehicle in March 2017, and I guess 3+ years is only the low end for what I'd expect for life, seeing as its used daily. How long did your original battery last, and any upgraded batteries available in addition to going up in size seeing as the space for that length wise?
Welcome. Moved to its own thread. If that mechanic is real confident in his diagnostics will he eat the cost of the fuel pump if that doesn't solve the problem? Please consider adding location and vehicle Model / Year to your signature - https://www.fordedgeforum.com/settings/signature/
Welcome and congrats on the new ride. Please consider adding location and Model/Year to your signature. https://www.fordedgeforum.com/settings/signature/
Not wise to mix the fluid types. https://www.cartechbooks.com/techtips/autotransfluid#:~:text=Mercon LV—the latest Ford,used to replace those fluids. I don't believe that only one Drain-Fill gives you 85-90% change - how did you arrive at those numbers. I would not climb under a vehicle while is half way up the ramps.
If its resistance from the orange seals, try some di-electric grease. https://www.amazon.com/CRC-05109-Technician-Electric-Applicator/dp/B000CCIDAA?ref_=fsclp_pl_dp_1
Welcome and congrats on your new ride. Please consider adding your location and Model/Year to your signature. https://www.fordedgeforum.com/settings/signature/
Welcome. Please consider adding your location and Model/Year to your signature. https://www.fordedgeforum.com/settings/signature/
AC Compressor replaced in error?
1004ron replied to PAT353's topic in Interior, A.C., Heat, Interior Trim
Welcome. This is going to be difficult for us to offer valuable advice when it appears you don't trust what the service shop is telling you. It would be best to have an AC specialist shop look at it, .....not a mechanics shop. Please consider adding your location and vehicle model/year to your signature. https://www.fordedgeforum.com/settings/signature/ -
Most certainly, and you'd have read in the other same topic threads that third party replacements for these fans are particularly problematic. https://en.wikipedia.org/wiki/Motorcraft Ford launched this auto parts division in 1972 to provide replacement parts and original equipment parts. https://www.motorcraft.com/ https://parts.ford.com/en/us/resources/motorcraft
