Everything posted by 1004ron
Welcome - please consider adding your location and vehicle Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ What you describe sounds like a bad FOB battery, so I would suggest that you check the batteries in both FOB's with a multimeter
When I bought mine I tried it but after about a week I turned it off and haven't used it since. I've not once tried the parking assist.
Locked out with both keys inside
1004ron replied to 1004ron's topic in Alarms, Keyless Entry, Locks & Remote Start
The dealership is closer to my work than home, so stopped by on my way home this evening and picked up my free Valet key. It worked perfectly. Now have my factory keyless entry code saved - the code on the card inside my owner's manual pouch is ***0* and the number displayed on the dashboard is ***9*, which of course is one and the same thing with the door keypad. For the method for displaying the code on the dashboard - I pulled the valet keys out of each FOB and placed them in the holder with the buttons facing up and the end where the valet key goes facing forward - tried other orientations and this was the only way that worked in my Sport. -
The owner's manual states that you can get the factory code from an authorized dealership - I'll try another dealership, and if they respond the same I'll get another key cut. Follow up from the service manager: I'd be surprised if Ford does not make the code available through authorized dealerships with the necessary proof of ownership. Waiting to hear how long it would take to get a key cut using the code. Edit: Dealership called to say he's cut a valet key for me using the code I provided and he's reasonably confident that will get me into the vehicle - free of charge. -
That one was also a used lease, but if it did in fact come from the factory like that it would be even more of a mystery. He doesn't report back on what the Dealership eventually did with the light bar, and they could possibly have corrected it. If it was bought new and the owner discovered it and it was in the model's spec. then Ford would have to make it right. BigBerky , how confident are you with electrics and electronics skils, are you 100% sure that its a non-illuminated light bar?
Thanks, Sent my dealership an email request for my factory code. Thank goodness I have alternate wheels for work tomorrow - my wife's away so I can use her Mustang, and its way too cold to use my bike. -
Damn, I wanted to set the drivers door code and had difficulty with what I thought was the factory code attached to one of my keys, and that wasn't working so I tried the procedure with both keys in the car, and had difficulty with that also and in the process I got out the car and as I closed the door it locked, ........and now I still cant unlock it with what I thought was the factory code. Will the Dealership be able to help me with the factory code? Looks like I'll be using my wife's car to work tomorrow. The attached photo is all I got from the Dealership - I assumed the code was 10778, would that be correct - if it is, then I'm not using it correctly.
Having done a fair amount of hobby electronics I'd assess the function of that Printed Circuit Board and possibly repair it, but with the tightly packed surface mount stuff these days repairs are way more difficult. You could try find a local electronics repair place who might be able to diagnose it for you. You could also post clear photos of both sides of the PC Board and we might be able to tell what its meant to do and offer some advice.
Must have bought the Orange stuff before it became obsolete.
Engine wants to stall - Code P1450 & P144A - Evap Purge Valve
1004ron replied to shumax's topic in 2017-2018 Edge & MKX
Does this happen only after filling up with gas, or at all times? I ask, because I used to top-off when filling up and it would do that whenever idling for the first 10 miles or so, and with my cheap OBDII device it showed no codes. Recently I bought the OBDLink MX+ and it showed an old stored code related to the evap. I've not had it do this since I stopped topping-off. -
Member's details not shown anymore?
1004ron replied to handfiler's topic in Forum Help & Site Suggestions
Sent an email to robertlane -
I just tried the link in your post above on my phone and laptop and both opened the PDF.
That's the best review site. https://www.headlightrevolution.com/better_lighting_led/low_high_fogs I used these on my motorcycle high beam and very happy with them - https://www.amazon.com/gp/product/B07XP1GG13/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 The 360 degree ones are reported to produce a more uniform pattern. https://www.amazon.com/Light-Moses-Degree-Headlight-Conversion/dp/B07RRBFYPH/ref=sr_1_1?dchild=1&keywords=led+360+degrees&qid=1611407397&s=automotive&sr=1-1
From 856 CCA to 826 CCA in 10 days - brand new battery
1004ron replied to Edgingage's topic in 2011 Edge & MKX
Below is all I would have done - always test a battery with it fully charged. -
The Gold is superseded / obsolete.
How to find my entry / posts
1004ron replied to 2017 SLE FORD EDGE's topic in 2015+ Edge & MKX Generation II
Click on your profile (top right) then near the top right click "My Activity". - While you're there, how about adding location and Model/Year to your signature - https://www.fordedgeforum.com/settings/signature/
