1004ron
    109
Everything posted by 1004ron
  1. Ford Support | Emissions Defect Warranty I changed mine at around 5 years and 75K miles and didn't give any thought to emissions warranty, but reading that I'd expect the evap purge valve should be covered.
  2. F0RDM0M yes, mine was past 60K so on Premium Care until 100K. It will be covered under warranty. Mine hasn't hickuped once since I installed the new purge valve.
  3. "Seems like a lot of waste" would be a personal opinion, but interested to hear how you came to that opinion. A quick forum search should answer your other questions.
  4. More surprising is the number of people that buy that kind of thing.
  5. Don't think an extractor will work well on the 2.7, but you should be able to extract just a little if the tube diameter is no greater than the dipstick width. Fast, Clean Oil Changes - Edge ST - Ford Edge Forum
  6. Wouldn't that apply to just about every brand out there?
  7. Not easy when they're hellbent on making enemies.
  8. Which NGK plugs do they have on Panda?
  9. That's a good deal, but I'd be concerned with it shipping from China, but most likely safe seeing some of the positive feedback left by those that have purchased this kit. I paid $1,300 for my wife's Mustang, and that included a new controls panel/bezel and tech support - I can put any interested parties in touch with this seller.
  10. For the PTU I would go for one of the top rated ones in the below list, which is for 75W90, but still a good guide for 75W140. I've been using Royal Purple and Redline but considering a change to Amsoil, oil Mobil-1
  11. (1) 2011 and Up Ford F150 3.5L P0016 Code - Chain or Chains Stretched Diagnosis Computer Part 1 - YouTube
  12. You should still have the bumper to bumper 36K mile warranty, and if so, let Ford fix it.
  13. Just stick with the oil you're using, or any other good name brand full synthetic of the correct grade specified in your owners manual. Not sure how long you've been around automotive forums, but "oil threads" are in abundance, and its typically the same as "how long is a piece of string?"
  14. @bhamraS97 I wouldn't take the covers off - it offers protection to things like the brake and fuel lines. I applied the foam washers and new fasteners as per the Tech Bulletin and as I commented in this thread it didn't silence it for long. I recently used zip ties and the buckle of the ties keeps the plastic posts cocked to one side and I believe that's going to keep quiet for longer.
  15. Welcome. Please add your ride and location to your profile signature - https://www.fordedgeforum.com/settings/signature/
  16. Yes I did - try a forum search for the threads containing that info. https://www.fordedgeforum.com/search/?q=forscan battery size https://www.fordedgeforum.com/topic/30280-group-65-battery-in-2nd-gen-possible/?tab=comments#comment-222764
  17. The ones I received in Feb 2021 are Gates, so surprised if they sent something different to you at around the same time. See the photos I posted in this thread.
  18. Mine is odor free and climate change, freezing temps, have had no impact on that. I would have continued use of mine even if it meant living with the odor.
  19. Ford does not have front or rear mudflaps for the Sport, and the Ford front mudflaps I used were not a good fit as can be seen in the above photo. The front and rear set bought on Amazon are a perfect fit. Amazon.com: A-Premium Mud Flaps Splash Guards Compatible with Ford Edge 2017-2020 Front and Rear Only Fit Sport Model 4-PC : Automotive
  20. Yes. 2013 FORD EDGE 3.5L V6 Spark Plug | RockAuto As WWWPerfA_ZN0W mentioned, the life span of the original Iridium plugs is also very good.
  21. I'd have to do more searching, but I recall reading that there's certain restrictions on programming the IPC to prevent manipulation of the odometer, such as only a new IPC can be programmed.
  22. I use these: Ruthenium HX™ Spark Plugs - NGK Spark Plugs
  23. For others that ask the same question: https://www.fordedgeforum.com/settings/signature/
  24. In the five years of ownership I've only had the stability control kick in once when on a sweeping bend that had a patch of ice. It kept me on the road, and took a good few miles for me to catch my breath. The ABS I've had kick in often.
  25. https://www.youtube.com/c/VanquishedAgain/search?query=edge Doesn't appear to hate the Edge ST in those videos.
