Everything posted by 1004ron
Replaced 2011 MKX Battery - Ambient Temperature Not Working
1004ron replied to Gustafa's topic in 2011 Edge & MKX
On mine the temp sensor is in the air filter box - I disconnected it when I removed the air-box for better access when I recently replaced my battery. Did you remove the air-box? Also, do a search for how to reset the Battery Monitory System (BMS) -
Welcome. What year? Please add your vehicle details to your profile signature - Settings - Ford Edge Forum
RyanA97 what's the service history? No, it's not normal. Could be poor maintenance resulting in sludge which causes issues with the hydraulic lifters.
Showing results for 'Forscan codes'. - Ford Edge Forum
Comprehensive List of Possible Forscan Mods? - Accessories & Modifications - Ford Edge Forum
I would use the "Drain & Fill" on the transmission until the drained fluid shows significant improvement.
Yes, if you don't have the service history then treat it as if every routine service item is overdue, engine oil & filter, air filter, cabin filter, spark plugs, trans fluid, PTU, ........etc.
https://www.mustang6g.com/forums/threads/need-to-level-out-the-front-drivers-seat.116469/#post-2448490 That is how I raised and leveled the seats in my wife's Mustang, and expect it should work for the Edge. Edit: keep in mind that you need two holes - one for the bolt and another for the dowel pin, so you'll need to drill a hole in the ones above in the Amazon link.
Is that the 2.0L Edge? Please add your vehicle Model/Year to your profile signature - Settings - Ford Edge Forum
2016 Rough Idle-Oil in plug wells after hard acceleration
1004ron replied to Cheyenne Carpenter's topic in 2.0L EcoBoost
Do a compression test and leak-down test. Switch the coils and see if the misfire code follows it. What did the old plugs look like, any one look different to the others? -
2019 Ford Edge ST Replacement Tire Options
1004ron replied to PokeTheBear70's topic in Wheels & Tires
On my 2017 Sport the original P-Zero's lasted 50K miles, and after that the Atturo lasted 31K miles. As the Atturo approached the wear bars, they were very bad on wet roads. My third set of tires just recently installed are Bridgestone Alenza AS Ultra 265 /40 R21 105V XL BSW and so far very happy with them - quiet and superb grip in the wet, and expect they'll be good in the snow. -
Whats leaking and should I be worried?
1004ron replied to DhaemonX's topic in 2015+ Edge & MKX Generation II
OK -
Didn't the mechanic say what he thought is leaking and from where? If the source of the leak isn't clear, then clean it off and watch it in the hope of identifying the source. -
The first one is Chinese and the second one Indonesian and hadn't heard of them until now. Not something I'd consider using.
That would help. What brand oil filter is installed - some filters don't have good anti-runback valves.
There isn't enough information to make an educated guess as to what is making the noise, and what could be causing it. For all we know it could be many thousand miles over on oil change - what's the oil look like on the dipstick?
What oil and oil filter have you been using and what oil change interval?
It doesn't take much to strip those plugs and/or the thread in the radiator. Post a photo of the two plugs together.
