Everything posted by 1004ron
Welcome. I can relate to that. I recently installed Bilstein shocks in the front struts of my wife's BMW X5 and didn't correctly torque the strut mount center nut - after correcting that the clunk was gone.
1004ron replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I haven't yet seen drifting done with FWD so hoping your video will be the first. -
Are you sure that's the correct headlamp assembly for the OP's specific model and option package? https://www.fordpartsgiant.com/parts/ford-housing-headlamp_kt4z-13100-c.html?vin=&make=Ford&model=Edge&year=2020&submodel=&extra1=&extra2=&filter=(r=446;e=414) @Revv my suggestion is to have an autoelec shop check it out in case its a bad connector etc. - as @omar302 its unusual for an LED to fail especially this early.
Welcome. Could you post the source of that information? Have you checked to see what your owners manual specifies for your Model/Year?
The edits as far as I can tell relate to the RDU in the video, which is the type found in my 2017 Sport, but don't believe its relative to the RDU being discussed in this thread.
@garycrist that video shows the RDU type in my 2017 and don't believe it has any bearing on this discussion. I have changed the RDU oil in mine and its regular gear oil which I don't believe will work in the RDU for the model/year Edge discussed in this thread.
For extracting fluids where there's no drain plug I use a wire coat hanger inside some clear tubing forming a shepherds hook, connected to my regular oil extractor.
Generally the differential oils contain friction modifiers which cause issues with wet clutches. Similar reason why its not good to use car engine oil in a motorcycle due to the wet clutch - motorcycle engine oil does not contain friction modifiers. Redline and Amsoil are top rated, so if they put it in writing that their oil is compatible I'd trust that. The Redline website kind-of indicates that its compatible. Interesting discussion here: https://bobistheoilguy.com/forums/threads/rear-differential-rdu-fluid-amsoil-alternative.401168/ And here: https://www.mavericktruckclub.com/forum/threads/rdu-rear-diff-non-oem-fluid-change-motocraft-xy-75w-qd-is-roughly-equivalent-to-a-synchromesh-gl-4-manual-transmission-fluid-not-a-gear-oil.75331/
Looks like the owner's manual calls for: Rear Axle Variant Quantity All. 28.1 ± 1.0 fl oz (830 ± 30 ml) Materials Name Specification Motorcraft® Disconnect Rear Drive Unit Fluid XY-75W-QL - MOTORCRAFT XY75WQL Gear Oil | Shop Now at RockAuto
Welcome. On the purge valve - I've followed a similar path, replaced the complete assembly with a 3rd party brand, replaced just the solenoid and both had a very short life - I'm on an OEM one for about 7 months with no issues.
Welcome. What work did you do on the AC and how do believe that work was related to the low oil pressure event? What rates do you charge?
Welcome. eBay is known for counterfeit spark plugs and other components. Best get Forscan and scan for codes as the starting point in your diagnostics.
Wow, that's more work than I'd be willing to do for that feature - turning off for me using the screen would also be an issue. I most often forget to turn it off when approaching the car was and their spray triggers the wipers and I have to scramble to turn the rain sensing off. My wife's BMW X5 is smarter - it turns off when the ignition is turned off and when you need it again with the first few rain drops you tap the button on the end of the stalk.
Don't have any suggestions other than checking for codes with Forscan.
Welcome. I'd be surprised if it doesn't have rain sensing wipers. Could you post a photo of the windshield looking from the outside directly in front of the rearview mirror - that would confirm if you have the sensor. If it doesn't have the rain sensor you'd probably need and new windshield, the sensor and possibly other electronics. Does it have the original or a Ford OEM windshield installed?
I found it reasonably accurate.
Welcome. If you buy a reputable brand they'll be direct replacement and will not trigger fault codes. LED's beam focus may have improved in recent years, but most I've seen that installed LED's into a light assembly not designed for them typically blind the oncoming traffic with the low beams ON.
The KYB strut mounts are widely considered to be problematic. KYB Strut Plus SUCK | BobIsTheOilGuy .
2014 Edge SEL 3.5 charging system deep dive( please help)
1004ron replied to jgaupel's topic in 2014 Edge & MKX
OK, that's good. How about the second part of the question? -
Just revisiting this - fairly risky to drain the coolant with it at normal operating temperature and even if that was done, it would be well below operating temperature with the new cold coolant just added and would take longer than 10 minutes to get back up to operating temperature.
