Everything posted by 1004ron
2022 Ford Edge Titanium - Auto Start System Not Working
1004ron replied to OhhBnertt's topic in 2.0L EcoBoost
Welcome @OhhBnertt Yes, it does sound like the battery is at its end of life, but before going out and buying a replacement do a load test on the battery and scan for codes - both those can be done at your local AutoZone or that type of store. If you go with a different spec battery then the vehicle needs to be coded to match, and whenever the battery is replaced the Battery Condition Monitor needs to be reset. -
Tail Light Moisture Condensation 2019-2024
1004ron replied to Wubster100's topic in 2019-Current Edge & Nautilius
Lucky in regards to not having the atmospheric/climatic conditions that would result in condensate inside the lamp assembly. My 2017 has also had condensate form a couple of times - I've not done anything to avoid it but haven't had a recurrence so not too bothered by it. -
Low Oil Pressure warning keeps coming on!!!
1004ron replied to vtchopperdude's topic in EcoBoost Mod & Tech
Welcome. What have you tried? What's the mileage? What oil change interval? What oil and oil filter used, and who does the oil changes? -
@Will2U Have you confirmed that those are in fact holes ? -
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
1004ron replied to shumax's topic in 2017-2018 Edge & MKX
Two tanks trial on the Dorman resulted in no fault codes and no stuttering immediately after gassing up, and just for to satisfy the tinkerer in me I tried a $9 solutions which also had a flawless two tank trial. -
As with the OEM mats, only the drivers mat has stubs holding them in place - the 3D mats engage in the same posts in the floor but have a cover on the topside which looks neater than the original mat. All the 3D mats have a material on the underside that grips the floor carpet reducing the chance of them sliding around.
We have had these mats in my wife's BMW X5 for one year and like them very much - a week ago while cleaning my Edge Sport I noticed that the drivers mat had worn through where my heel rests and allowed snow and water to wet the carpet. My Sport came with rubber mats which were OK, but nowhere near as nice as the ones that were delivered today. They fit way better than the Ford ones, look far better and are much easier to clean. https://3dmatsusa.com/collections/custom-fit-car-floor-liners/products/kagu-floor-liner?model=MjAxN0BGT1JEQEVER0U= SKU L1FR09301509 Coupon Code for $10 off - GJEEBS3D10
New phone techology limitation 2020 Edge
1004ron replied to BamaInArk's topic in Audio, Backup, Navigation & SYNC
Have you tried it without the case? -
Best get the stored error/fault codes read and that should offer some direction - I'd guess that it's the evap system, but reading the codes is the way to go.
Agree, if those were holes, you'd have an issue going through a car wash - drain holes are typically at a low point and protected against water jets. -
The administrators finally responded and created the subsection - 2019-Current Edge & Nautilius
Was it with a full tank of gas?
