1004ron
    121
Everything posted by 1004ron
  1. From @Dasher21591 I've also encountered this - instead of indicating that the file is too large it posts blanks. Very doubtful the forum owners will correct this, so just make sure you reduce the file size before posting.
  2. Have you checked your owners manual for the bulb spec and tried Autozone for replacements?
  3. Get the stored error codes read, be be aware that not all code scanners are reliable - I learnt that lesson and now only use Forescan Lite to read codes.
  4. The past few weeks there's been a few accounts obviously hacked and used to post malicious links. If you see such posts best you don't let your curiosity and click on the links, and use the "report post" button. The only option was to ban the hacked users accounts. This would be a good time to strengthen your account password.
  5. Please consider adding your location and vehicle Model and Year to your signature - https://www.fordedgeforum.com/settings/signature/
  6. Post a photo of the broken clip. If its the retaining clips, then it will have no impact on the valve or engine unless the connection falls off - the O-ring inside the fitting keeps it sealed. EVAP Tube Quick Release Coupling Clip - where to buy? - 2.7L EcoBoost - Ford Edge Forum
  7. Give the forum search feature a try.
  8. Please add your vehicle details to your profile signature - Settings - Ford Edge Forum
  9. @Zand Zadyen Frank please add your Model & Year to your profile signature. headlamp assembly - Accessories & Modifications - Ford Edge Forum
  10. I'd forgotten, so took a look and see that the front use the plastic rivets and the rear uses the existing hex head screws. Its a lot easier if you take the wheels off.
  11. From around 2010 vehicles no longer used an IAC - electronic throttle body is what they use. I would start by getting the stored error codes read.
  12. Is it the original battery? Need to get the battery load tested - you could jump start it and have a place like Autzone test it.
  13. https://www.amazon.com/gp/product/B083L9NS9D/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Same issue with the Sport, Ford don't make any that match the profile of the body trim. I don't know how different the ST body trim is, but the ones I bought on Amazon are perfect - you could contact that seller and see what they have for the ST.
  14. Firstly, keep it to this thread - stop cross-posting. If air got into the system then you'll need equipment to bleed the ABS system - sounds like your 3 mechanics aren't suitably qualified and equipped, so consider taking it to the dealership or find a reputable independent shop. Note, I haven't read your first post because the wall of text doesn't make for an easy read - it wouldn't take much to use a little punctuation.
  15. Tell us what you've already checked. Have you had the stored error codes read?
  16. 1004ron
    Short Rant
    I'm a relatively new wireless CarPlay user - I can switch from any app such as Waze to Sync, turn on or off the steering wheel heat and while on the Sync screen hit "maps" and I'm back in Waze, or any other Carplay app.
  17. My local dealership said it was a major undertaking to try and get the keypad code from Ford, and to date they'd never actually accomplished that. With the photo that I had of my keys with the code they cut a physical key for me which allowed me to get into the car - this was when I accidently locked both sets of key fobs and keys inside the car.
  18. Please add that to your profile signature - https://www.fordedgeforum.com/settings/signature/
  19. The key is to monitor your coolant and oil level, and if there's no drop in either of those then its most likely climatic conditions causing water vapor from the exhaust.
  20. This wouldn't be much of an issue with our FWD and AWD, but not sure about accident liabilities etc. I had issues with my wife's RWD Mustang and would have got rid of the P Zero's sooner had I know this limitation. https://www.mustang6g.com/forums/threads/popping-noise-in-front-passenger-suspension.181435/page-2#post-3676964
